Hello Guest it is October 24, 2026, 09:26:36 PM
Author Topic: Mach4 engraving CNC laser machine missing steps and regaining them ...?  (Read 18372 times)
  •  9,374 9,374
Your Gcode looks fine, which motion controller are you using ?
i'm using the pokeys 57 CNC
But the i also trie this in MDI
G00 X20
M62 P1
G00 X0
M63 P1
and the output stays high all the way tru....?
  •  9,374 9,374
I do use a 57CNC for laser work but not with Mach4 so I do not know if the 57CNC actually supports the M62/M63 commands. May I suggest that you contact PoLabs to check this before proceeding;   http://support.polabs.com/
« Last Edit: July 22, 2018, 07:16:21 AM by Tweakie.CNC »
i will check it,  but i don't think the gcode M62-63  has ennything to do with the pokeys 57cnc   it is in mach 4  ....?
mach 4 reads the M62-63  an just puts this to an output of the pokeys....
  •  9,374 9,374
So it would seem but...
Because the M62/M63 commands only take effect at the instant of axis movement then the Output# would have to be controlled by the 57CNC plugin.
I got this from polabs
We are in contact with Mach4 team on how to solve this issue and implement real-time outputs control.
 So you were right
  •  9,374 9,374
My apologies for suggesting the M62/M63 route - looks like you are back to using an axis direction pin for the time being.
However, I think PoLabs will be pretty quick to implement these commands into their plugin.
