Hello Guest it is October 25, 2026, 12:30:53 AM
Author Topic: Keyboard Increment Jog  (Read 7748 times)
« on: July 16, 2018, 01:54:32 PM »
I am having an issue with the increment jog.  When I try to increment jog from the keyboard by pressing ctrl and then the arrows or the page up/down buttons it only moves in the x-axis. I have tried changing the button from ctrl to shift and I am having the same issue.
Could someone please help me figure out how to fix this?
Re: Keyboard Increment Jog
« Reply #1 on: July 16, 2018, 03:38:59 PM »
What version are you running?  I had this problem several versions back and had to use a different version of the keyboard plugin to fix the issue.
Version 3805 all increment moves are working just fine for me right now.
Chad Byrd
« Reply #2 on: July 19, 2018, 02:06:15 PM »
Thank you for your quick reply. I will update the software as soon as the part we are machining is completed.
Thanks again, I will update asap.
« Reply #3 on: July 25, 2018, 01:07:51 PM »
updating the software fixed the problem.
thank you for your help! :)
« Reply #4 on: July 25, 2018, 01:10:36 PM »
No problem!  Glad you got it working!
Chad Byrd
