Hello Guest it is November 13, 2026, 09:36:22 AM
Author Topic: mach 3 plasma table strange happenings!!  (Read 11774 times)
« on: July 10, 2018, 04:57:44 AM »
Hello
Just had an issue with my mach 3 installation win 7
Machine has been working fine for a  good while.
it is using a uc 400 eth motion controller.
the problem is that the x and y axis are not moving at the same feed rate (I think)
for instance if the machine is going to start a cut at 100,100 and it traverses diagonally to that point, it will stop at 90,100 and then zero the z, the g code re references the xy point after zeroing the z and so it then moves the x axis to 100.
Unfortunately when cutting radii it turns them into chamfers!
if i enter g code to move on the x axis, the feedrate goes up and down, both on the mach screen and noticeably on the machine.
If i just jog the machine or ref all home then the feed is stable!
The g code files are the same ones I have been using with no problem.
The machine has no stiff points on the axis either way
In motor tuning x and y have the same velocity and acceleration.
Any ideas
Re: mach 3 plasma table strange happenings!!
« Reply #1 on: July 10, 2018, 06:23:52 AM »
So curiously I restarted the pc 3 times and it seemed to fix itself!
  •  9,377 9,377
« Reply #2 on: July 10, 2018, 06:36:27 AM »
No explanation but let's hope it stays fixed.  ;)
