Hello Guest it is November 23, 2026, 10:13:58 PM
Author Topic: Calibration issue (I think)  (Read 6480 times)
« on: July 08, 2018, 04:33:59 PM »
Strange problem.  I am using Mach 4 on a win 7;computer running gcode produced in Fusion 360.
I noticed that I was  a mm or two out of calibration, so I decided to recalculate all three axis. X went great, but I had to change units from 33.something to 60.something on the y axis.    Seemed weird sinse it was only out by 1.5mm or so, but I made the change and when I measured the y movement, it was spot on.  I did a test run (75mm circle inside a 100mm square).and x was ok, but y was almost twice what it should be.  I checked the calibration again and it still moved exactly 200 mm for the y 200 command.  The tool path appears normal in the preview window.
Is there some setting somewhere that would cause the units to be off by that much during a job even though calibration seems fine?
Offline smurph
  •  1,575 1,575
Re: Calibration issue (I think)
« Reply #1 on: July 10, 2018, 04:49:37 PM »
What is the Mach build number?
