Hello Guest it is November 22, 2026, 07:07:02 AM
Author Topic: Pull-up Resistors  (Read 12715 times)
Pull-up Resistors
« on: July 22, 2007, 09:51:56 PM »
Hello,
Can someone please direct me to information on pull up resistors?
Thank you,
Ken
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Pull-up Resistors
« Reply #1 on: July 22, 2007, 10:36:07 PM »
Hi, Ken
I think theres a description on the Rutex web site.
There tied to the A & B lines then to 5 volts TTL encoders, Around 470 ohm's, Hears the link to look at,
http://www.rutex.com/pdf/R9xHbdi.pdf   , page 7.
Hope this Helps, Chip
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: July 26, 2007, 02:47:16 PM »
Ken, that's a pretty wide open question.  What are you trying to accomplish, hook up etc?  If you can give us an idea of what you are trying to do, then perhaps someone can tell you how pull-up resistors relate to that subject.
Happy machining , Jeff Birt
Offline comet
  •  338 338
« Reply #3 on: July 26, 2007, 03:25:05 PM »
hi,
 I will asume you are refering to encoders? in which case you should refer
to the manufacturer of the encoder's specsheet.
