Hello Guest it is November 13, 2026, 09:36:37 AM
Author Topic: centre part on table (probably a silly question)  (Read 9534 times)
« on: July 03, 2018, 11:35:36 PM »
Hi Forum,
i have headed back to the workshop and it appears i have forgotten a lot... :-(
I loaded G-code (all good)
set my XYZ DRO to zero on centre of part etc.. (seems ok)
set machine coordinates to 0.000 (to DRO)
but.......
my part is still showing at the edge of the table which appears to be causing all sorts of odd moves.....- see attached
Q... How to i set do my part is centered on the table?
Offline rcaffin
  •  1,073 1,073
Re: centre part on table (probably a silly question)
« Reply #1 on: July 04, 2018, 05:30:39 AM »
I am not sure what those white dashed lines mean. However, The crossed purple lines show you where the origin is: righ in the middle of the part.
Lift the spindle up a bit, well clear of the part, Zero it up there, stick a bit of 1/8" PVC welding rod in the chuck, drop the feed down slow (slider), and push the Go button. This is called 'cutting air', and we all do it!
Before you do, click on ToolPath (tab 3) and see what the movement limits are. Make sure they won't cause grief.
Roger
« Reply #2 on: July 04, 2018, 09:29:20 AM »
Zero the machine coordinates first (home the machine)
Then set XY zero in the center of your part.
« Reply #3 on: July 04, 2018, 10:43:05 AM »
You don’t need to home the machine unless you are using a tool changer or soft limits in most cases. I have limit switches that prevent a hard crash but they don’t require homing.
« Reply #4 on: July 04, 2018, 01:36:15 PM »
because OP was not homing the machine is why the toolpath display was so far displaced from the center.
