Hello Guest it is October 24, 2026, 11:04:50 PM
Author Topic: I NEED ''Enable'' an ''Cycle Start'' scripts for activating with a ESS input  (Read 28512 times)
or buy another BoB, or even two, for $23.00 each and have as many inputs as you could shake a stick at!
Which bob is $23.00 that your talking abought
I meant the C10 BoB, it has a bi-directional buffer which allows pins 2-9 to be used as inputs
whereas the kl-bd25 pins 2-9 can ONLY be used as outputs.
You need more inputs and so a BoB which has bi-directional pins 2-9 is what you need.
you could use the C13 at only $9.00 but it has no buffer ICs, if you have a cock-up with the wiring
you could blow the ESS. I prefer BoBs with a buffer, blowing a cheap BoB I'd live with but I'd be
p.....sed off if I blew my ESS!
you can use your keyboard num pad, I tried it a few years ago and it worked
What do you mean, im tryn to figure out how to activate by keyboard instead of by input button,... in other words how do i make say enable work when i hit a keyboard input like spacebar or another keystroke
