Hello Guest it is October 01, 2026, 03:36:24 PM
Author Topic: Mach 3 changing stepper motors configuration  (Read 7676 times)
« on: June 28, 2018, 08:47:42 AM »
Hello,
I’m changing the z axis on my cnc router. Going from a rack and pinion driven straight from the stepper to a linear slide screw drive like this one. https://www.automationtechnologiesinc.com/products-page/cnc-parts/cnc-z-axis-slide-10-trave/
How or what do i change in Mach 3 to make this work?
Re: Mach 3 changing stepper motors configuration
« Reply #1 on: June 28, 2018, 01:34:39 PM »
just enter the correct 'steps per unit' value in the Z axis tuning page. You will have to experiment to find the correct max velocity and accel.
Good place to start is the speed of the axis if the stepper is doing 500 rpm. Thus if the axis has a 5mm pitch ballscrew then the max velocity
would be in the region 500 X 5 =2500 mm/min. Common to start with accel of 10% of the max velocity, so accel=250.
