Hello Guest it is November 13, 2026, 09:35:10 AM
Author Topic: 2 Cents Part 2, more help needed  (Read 15519 times)
« on: March 25, 2006, 07:38:39 AM »
Hi guys. I have tried to use the G56 fixture area while setting up to run my first part. Then I get back to the main screen and try to posititon it on the screen that shop my table, that's when it hits the fan. As soon as I try to move in that area with my mouse it go haywire, losses it's orientation and goes rotational on me. Any input as to what I'm doing wrong here. Oh the machine drilled a hole deep into the table and tried to move from deep in the substrate..
Re: 2 Cents Part 2, more help needed
« Reply #1 on: March 25, 2006, 01:20:16 PM »
can you get it to run if you use the G54 offset?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 26, 2006, 10:05:17 AM »
Brian, I I've been so busy with a room repaint I haven't had time to try. I am not at all versed in cam at all I believe some of me trouble lies there but I should be able to get to work.
