Hello Guest it is November 13, 2026, 10:36:04 AM
Author Topic: Accurate when jogging, not accurate when cutting?  (Read 9504 times)
« on: June 18, 2018, 03:19:36 PM »
Hey Everyone,
I have exhausted my google ability trying to figure out whats wrong with my machine so forgive me if it is an easy fix!
I'm finishing up construction of a simple CNC table for cutting sheet material and everything has gone fairly well, the problem is when I jog the machine, or manually input a movement for say 100mm it is extremely accurate.
But when I output my toolpaths from Cut2D my cut is off exactly 1mm on x, and 1.4mm on y.
I have checked everything ten times, and I've used two different versions of Cut2D on two different computers, and also Aspire 8 and I still get the same inaccuracies.
Do you have any suggestions?
Thanks a million
Offline TPS
  •  2,627 2,627
Re: Accurate when jogging, not accurate when cutting?
« Reply #1 on: June 19, 2018, 01:56:52 PM »
Config -> General Config
Motion Mode
Constant Velocity ?
Exact Stop ?
« Reply #2 on: June 19, 2018, 02:00:29 PM »
Thanks for the suggestion! I will try it first thing tomorrow (Irish time!)
Offline TPS
  •  2,627 2,627
« Reply #3 on: June 19, 2018, 02:02:56 PM »
nearly the same as Bavarian Time ;)
