Hello Guest it is November 24, 2026, 11:11:18 AM
Author Topic: Can I run two axis with one hot key  (Read 13043 times)
« on: July 21, 2007, 10:55:11 AM »
I want to move both X and Z axis at the same time when pressing on a keyboard left arrow.
I still need to be able to control each axis independly (another set of two hot keys)- so slaving is out of the question
Is this possible ?
« Last Edit: July 21, 2007, 10:57:58 AM by tbarnea »
Re: Can I run two axis with one hot key
« Reply #1 on: July 22, 2007, 02:23:56 PM »
You can turn Slaving on wilth
OEM Button 357 will disable the slaving
and OEM button 358 will enable the Slaving :)
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: July 23, 2007, 04:09:32 AM »
Thanks Brian
Can I slave Z to A and at the same time A to Y ?
I am running a CNC foam cutter which is a 4 axis machine
I need to be ablt to run both X and Z at the same time as well as Y and A
Thanks again
Tal
« Reply #3 on: July 23, 2007, 06:44:41 AM »
If you setup the slaving they should do it :)
Brian
www.machsupport.com
Offline Greolt
  •  956 956
« Reply #4 on: July 23, 2007, 08:07:02 AM »
This is a capture of a section of the Wiki that pertains to OEM buttons
Looks like you can do it no problem.
Just need to change the name of Z to A
Will that muck up your gcode?  I guess it would.
Greg
« Last Edit: July 23, 2007, 08:10:25 AM by Greolt »
« Reply #5 on: July 24, 2007, 09:12:21 AM »
That should work as well :)
www.machsupport.com
