Hello Guest it is August 09, 2026, 07:02:11 PM
Author Topic: Ghost in the machine  (Read 6704 times)
« on: June 13, 2018, 09:31:54 AM »
Hi Chaps, ghost in the machine today..... using a cnc router/mach3 combo for a couple of years now an no problems apart from teething problems. Today I go to set the machine up as normal for a repeat job. Load the code and hit cycle start, normally the spindle starts automatically and it starts the cut..... but today the spindle is not starting auto, I have to hold feed - start spindle manually - cycle start again, and it continues the cut and finishes as normal.
Everything in the set up is the same, g code provided by Aspire as normal...
Any ideas ?
Re: Ghost in the machine
« Reply #1 on: June 14, 2018, 02:57:58 AM »
All sorted now - stripped out control box, cleaned all connections and reassembled - thanks for all the suggestions guys, you were a great help :)
