Hello Guest it is November 13, 2026, 11:28:40 AM
Author Topic: servos for hi speed  (Read 15207 times)
servos for hi speed
« on: March 24, 2006, 07:44:07 PM »
hi locking to build an 3 axis cnc for cutting glass (scratching it whit an diamond) and i need speed of 20 inches/sec
the table would be 2/3 metres
I'm new in this and i need whole the advice
watt is the maximum speed whit servos ?
does SERVOS work whit MACH ?
what should i consider before starting buying thestuff i need  ?
what should i consider before starting buying the stuff i need ?
1 or 2 motors for x axe ? if 2 do they need separate drivers ?
leadscrew or belt ?
em i right to think that i need servos ?
               thank you
Re: servos for hi speed
« Reply #1 on: March 24, 2006, 07:54:44 PM »
You are going ot need sevo's and you are going to need some Hp to get that done... look at AC servo's..
www.newfangledsolutions.com
www.machsupport.com
