Hello Guest it is November 22, 2026, 03:55:06 PM
Author Topic: Is it the movement speed of the system?  (Read 13967 times)
« on: July 19, 2007, 09:13:47 PM »
I operate MACH3, and it sometimes happens that the drawing speed of the computer puts away very late when finished afterwards.
Can you easily return this normally?
What are these causes? ???
Re: Is it the movement speed of the system?
« Reply #1 on: July 20, 2007, 06:15:33 PM »
Sorry dont understand what you are asking :(  Can you try and rephrase it and hopefully we can help you out.
« Reply #2 on: July 20, 2007, 11:06:39 PM »
Because English is not a mother tongue, it is not correctly expressible.
After it ends when I operate "MACH3", "WIN2K" doesn't recover former speed.
It becomes energetic when rebooting.
Does "MACH3" rewrite program "Table of the task in WIN2K"?
For instance, the performance cannot be put out at all actually though "FT245RL" must be
enough as the update rate with transfer rate (D2XX) of about 1MB/a second.
« Reply #3 on: July 31, 2007, 05:35:05 PM »
I think I found the same problem.
When using mach the computer slows down. Literally. Every second on the clock is around 15 real seconds.
Everything just slows down. Mach only updates the DRO once every second.
Even the update of the task manager in windows slows down.
Ill be back after a restart.
« Reply #4 on: August 03, 2007, 07:14:56 AM »
Has no one else got the same problem. It does this every time i start mach.
If I play music the sound already in the buffer repeats itself until it is fed the next part of the song wich comes in due time.
Is is anything you want me to do to help you figure out the problem?
Or should i start a new thead with a flashier title?
btw the driver test does the same "black squares" that covers nearly the entire graph.
*edit* 1 second on the computer is exactly 10 real seconds.
« Reply #5 on: August 04, 2007, 03:24:32 PM »
Use msconfig and stop any programmes that load at startup and see if that helps, I know that Quick time can cause real problems with Mach so if you have that installed  it may be your problem.
