Hello Guest it is November 22, 2026, 09:39:25 AM
Author Topic: Set Machine Coordinates in VB or G-code  (Read 9502 times)
« on: July 18, 2007, 02:08:34 PM »
Is it possible to set the machine coordinates to a desired value (without homing the axis)?
I have tried SetOEMDRO(1024,some_value) but the Machine Coord DRO is read only.
I have also played with #5161, G10, G52, G92.  These all only affect the Workoffset.
If it is not possible I will just have to settle for using G52 to compensate.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Set Machine Coordinates in VB or G-code
« Reply #1 on: July 19, 2007, 03:54:06 AM »
I am still learning so pardon me asking - why ??? On Mach3 turn you can jog to a suitable point - usually a known place on your workpiece and then zero the co-ordinates, so the program knows where it is.
I cannot see why you want to introduce co-ordinates from the program, when the table doesn't know where it is ???
Or are you trying to do a shadow of your original cut merely by moving the start co-ordinates ?? (I just though of that !!)
