Hello Guest it is November 13, 2026, 09:46:36 AM
Author Topic: Problems with ref all home  (Read 21380 times)
« on: May 01, 2018, 09:48:07 AM »
I have a small cnc router with a 4 axis setup using slaved motors to run the gantry. Was using a gecko 540 and an ess, recently replaced the g540 with a leadshine mx4660. Love how much quieter and smoother the new drives are.
I'm having an issue when homing, the slave axis isn't coming off the switch. Single switch on each axis, just for homing. When I hit ref all home it homes the z, then the y which is the one that is slaved, the the x. It zeroes all 3 axes, then an error pops up in the status window to the effect of "requested home axis is active please fix then home".
If I watch the gantry the slave stops when the switch triggers, but never pulls back off the switch. This is really obvious since I use hall effect switches so there is a pretty good overlap between where it triggers and where it goes back off.
Re: Problems with ref all home
« Reply #1 on: May 01, 2018, 01:03:34 PM »
so you have one home switch for the gantry but two motors?
I think your problem is more to do with slaving than homing. Try a few searches on 'slaving'.
« Reply #2 on: May 01, 2018, 01:16:00 PM »
No, there's one switch for each axis, Y, A (slaved to y), X, and Z, just no limit switches. The machine worked great for 3 years with the gecko.
« Reply #3 on: May 01, 2018, 01:33:52 PM »
So the Y motor pulls back but the slave (A) does not?
« Reply #4 on: May 01, 2018, 01:37:04 PM »
can you post a screen shot of your Homing/Limits page?
« Reply #5 on: May 01, 2018, 02:00:25 PM »
Yeah, the y pulls back properly but the a doesn't. I'll get a shot of the homing limits page as soon as I get off work. It even sets the zero, and doesn't put an error in the status window until afternit finishes the x axis.
« Reply #6 on: May 01, 2018, 09:15:49 PM »
Not sure what has changed, went to take the pic of the home/limits screen and when I came back out and tried it it worked. This isn't the first time I've looked at that screen either, rebooted the computer, mach 3, the electronics multiple times.
If it doesn't stop working again I'll chalk it up to software glitch.
« Reply #7 on: May 02, 2018, 10:30:18 PM »
Well, started having issues when I fired it up today. Doing the same thing it was. It's like it isn't even trying to home the slave, the diagnostic light for the slave lights up before the master, but the slave doesn't stop until the master does.
I swapped the wires for the X (not the master) and the A, the X homed fine, slave did the same thing. Swapped the actual switches from Y to A thinking maybe one of my hall effect switches was bad, no change.
Messed with it bit longer and it suddenly starts working. I have also had the e-stop trigger for n o reason a couple of times, so I may have a noise issue. Though the Y and A switches only get near any other wiring right where they connect to the mx4660. All the grounds are  bonded my motor cables and limit switch cables are shielded. Only thing I can think of to try, is powering the input opto isolators with the same 12v supply the switches are powered with instead of the internal one on the mx4660.
I even tried upping the noise cancellation in mach 3 to like 10000. Didn't seem to effect it, it just seems to work sometimes and not others.
« Reply #8 on: May 02, 2018, 10:42:47 PM »
Here is a screenshot of my home-limits screen.
« Reply #9 on: May 02, 2018, 11:14:00 PM »
I'm confused, I thought that if you have a motor slaved, and permanently so, ie that they cant be unlinked to square the
gantry then ONLY the primary axis is checked for homing. If both the master and the slave are checked then Mach will
look for TWO home switches.
If I'm guessing correctly Mach is looking for a second home switch and is not finding it.
May I suggest confirm that Y and A are slaved on then Slaving page and uncheck the A axis homing on the Home/limits page.
I would expect that you have ONE home switch for the Y axis  checked on your inputs page, ie no A axis home switch enabled.
