Hello Guest it is November 10, 2026, 02:17:53 AM
Author Topic: Auto corner finding problem  (Read 11108 times)
« on: April 29, 2018, 06:27:43 AM »
Good morning
I have a problem with the following script
if I cast Y-Y + X-X + everything works fine instead for the corner search gives me problems
1 press the corner button
2 part and touch the z-
3 rises, moves for probing in x +
4 goes down
at this point it crashes and I get out the words "Probe plate is grounded, check and try again" I state that if I run the script from the window works well, I have done many tests I can not get over it.
Ps: the problem and with all 4 corners
Rem   Auto corner finding X-Y+Z-(button4) With tool diameter Input Metric Version
   Speak (" CONFERMARE RICERCA ANGOLO INFERIORE DESTRO") 'Avviso Vocale
Message "INIZIO RICERCA ANGOLO"
Sleep (1000) ' pausa di 1 secondi
response = MsgBox ("CONFERMARE RICERCA ANGOLO")
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(1000) 'gets the current tool diameter
If GetOemLed (825)<>0 Then 'Check to see if the probe is already grounded or faulty
   Call ProbeGrounded()
   Exit Sub
Else
   DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
   Code "G4 P2" ' two second delay
   Code "G90 G31 Z-25 F100" 'Z goes down a max of 25mm at 100mm/sec
   While IsMoving() 'wait while it happens
   Wend
   ZProbePos = GetVar(2002) 'get the axact point the probe was hit
   Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
   While IsMoving ()
   Wend
   Call SetDro (2,0.000)
   Code "G4 P0.25" 'Pause for Dro to update.
   Code "G90 G0 Z15" 'retract Z to 15mm
   Code "G91 G0 Y3 X25"
   Code "G90 G0 Z-5"
   Code "F" &CurrentFeed 'Returns to prior feed rate
End If
Rem   VBScript For probing In the x- direction
If GetOemLed (825)<>0 Then    'May need to use =0 if it errors
   Call ProbeGrounded()    'Check to see if the probe is already grounded or faulty
   Exit Sub
Else
   Code "G4 P1"         'Pause 1 second to give time to position probe plate
   Code "F100"
Rem   Probe Left
   XNew = GetDro(0) - 75      'probe to current position - 75mm
   Code "G31 X" &XNew
   While IsMoving()      'wait for prob move to complete
   Wend
   XNew = GetVar(2000)      'read the touch point
Rem   move back To the hit point incase there was an overshoot
   Code "G90 G0 Z15"
   Code "G90 G0 X" &XNew
   Code "G91 X-" &CurrentToolDiameter/2  'moves the probe half the tool diameter to center on edge
   While IsMoving ()
   Wend
        Call SetDro (0,0.000)
        Code "G4 P0.25"
        Code "G91 G0 X-5 Y-25"
        Code "G90 G0 Z-5"
   Code "F" &CurrentFeed       'restore original feed rate
End If
Rem   VBScript For probing In the Y+ direction
If GetOemLed (825) <> 0 Then       'Check to see if the probe is already grounded or faulty
   Exit Sub
Else
   Code "F100"         'Slow feedrate to 100mm
Rem   Probe up
   YNew = GetDro(1) + 75      'move to current y position + 75mm
   Code "G31 Y" &YNew
   While IsMoving()      'wait for the move to finish
   Wend
   YNew = GetVar(2001)      'read the touch point
        Code "G90 G0 Z15"
   Code "G90 G0 Y" &YNew
        Code "G91 Y" &CurrentToolDiameter/2  'moves the probe half the tool diameter to center on edge
   While IsMoving ()
   Wend
        Call SetDro (1,0.000)
        Code "G4 P0.25"
        Code "G90 G0 X0.0"
        Code "(X, Y, and Z axis' are now zeroed)"
        Call ReturnG90G91State()
        Exit Sub
End If
Sub ProbeGrounded()
   Code "(Probe plate is grounded, check connection and try again)"
End Sub
Sub ReturnG90G91State()
   If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
      Code "G91"
   End If
   If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
      Code "G0"
   End If
End Sub
Re: Auto corner finding problem
« Reply #1 on: April 29, 2018, 06:31:49 AM »
What version of Mach3, and what motion controller, if you are using one?
« Reply #2 on: April 29, 2018, 07:24:11 AM »
thanks for the reply Gr21
use mach3 Version R3.043.062 port lpt
Offline TPS
  •  2,627 2,627
« Reply #3 on: April 30, 2018, 11:02:52 AM »
then you hit the probe during Z- move
VBScripter Window step through
« Reply #4 on: April 30, 2018, 12:15:54 PM »
thanks for the help of TPS
I do not know what you mean
I did a test I changed:
If GetOemLed (825) <> 0 Then 'May need to use = 0 if it errors
with
If GetOemLed (825) = 0 Then 'May need to use = 0 if it errors
it works, but I do not know if it's done well or if it's dangerous, from some tests it works well
Offline TPS
  •  2,627 2,627
« Reply #5 on: April 30, 2018, 12:23:49 PM »
your Change is defintly nor ok.
try this:
   Exit Sub
Else
   Wend
   While IsMoving ()
   Wend
   Code "G90 G0 Z-5"
   while IsMoving()
     sleep(10)
   Wend
End If
   Exit Sub
Else
   Code "F100"
Rem   Probe Left
   Code "G31 X" &XNew
   Wend
   Code "G90 G0 Z15"
   While IsMoving ()
   Wend
        Code "G4 P0.25"
        Code "G90 G0 Z-5"
   while IsMoving()
     sleep(10)
   Wend
End If
   Exit Sub
Else
Rem   Probe up
   Code "G31 Y" &YNew
   Wend
        Code "G90 G0 Z15"
   While IsMoving ()
   Wend
        Code "G4 P0.25"
        Code "G90 G0 X0.0"
        Exit Sub
End If
Sub ProbeGrounded()
End Sub
      Code "G91"
   End If
      Code "G0"
   End If
End Sub
« Reply #6 on: April 30, 2018, 12:52:32 PM »
ok TPS works well (as always you're a big one ;) ;))
I have also added
XNew = GetVar (2000) 'read the touch point
Code "G91 G0 X2"
is
YNew = GetVar (2001) 'read the touch point
Code "G91 G0 y-2
it works, but can it create problems?
greetings and again THANK YOU !!
