Hello Guest it is September 15, 2026, 12:58:09 AM
Author Topic: laser/impact engraver  (Read 9893 times)
rossmartin
« on: July 17, 2007, 10:26:56 PM »
Thanks in advance. I'm getting an output on the digital trigger (port 1
pin 14) when I have the laser trigger turned on and the grid set to any
value (x=n) (y=n). When I load the plugin it runs just like it should, but when it
starts the scan I don't get any output pulses on my scope without the
laser trigger turned on. Then the pulse train only follows the values
that are entered into the grid parameters not the greyscale image.
What am i missing? I would like to use my laser (TTL trigger) with M3
Thanks so much for everything.
Ross Martin
Re: laser/impact engraver
« Reply #1 on: July 21, 2007, 03:05:25 AM »
Is somewhere a description of this plugin? I am interested in impacting engraving feature, and I do not know how to use it. I just downloaded it and I want to install and experiment with it.
Thank you.
Zoltan
« Reply #2 on: December 26, 2007, 03:39:35 AM »
Hi, has anyone got any further with the laser engraving plugin? I am also having problems making it work with my laser system, and I cannot find any other help files or information on how the plugin works, or how it can be modified.
Thanks in advance,
Ilya
