Hello Guest it is November 13, 2026, 05:33:10 PM
Author Topic: Hotkeys are not working  (Read 8749 times)
« on: April 26, 2018, 01:08:49 PM »
Hi there
I am trying to change my axis, through hotkeys but nothing is happening.
what i want to do is change my left and right to be my Y axis, and up and down arrow to be my X axis, Is this possible?
What I did was going Config>System Hotkeys>and I press X++>"SetHotKeys"> Then I press the Up arrow, but nothing happens.
What is it that I need to do?
regards
jhonansaro
  •  9,377 9,377
Re: Hotkeys are not working
« Reply #1 on: April 27, 2018, 12:39:57 AM »
You should notice the Scan Code for X++ has changed to 38.
If this does not happen then check your keyboard operation is OK.
If keyboard is OK then I suggest you reload Mach3 from scratch.
« Reply #2 on: April 27, 2018, 11:18:52 AM »
Hi Tweakie
thanks for the reply. Strangely this time as I tried to change my Hotkeys, The X++ value has indeed changed to 38, but before it never changed.
My lap top is not connected to my Machine controller at the moment, I will try it in actual world tomorrow I will let you know.
reagards
jhonansaro
