Hello Guest it is November 23, 2026, 03:26:23 AM
Author Topic: mach 3 not working?  (Read 18747 times)
mach 3 not working?
« on: April 15, 2018, 06:30:39 PM »
hello all, I have had my machine (3040t) for about 2 months, and now when i load a file into Mach 3 in the display window you dont see the pic that is going to be made. instead you see a very small version in the box, and when the program starts is only moves the machine about an 1/8 of an inch.
this may seem very vague, and im sorry for that.. still learning
Eric
Re: mach 3 not working?
« Reply #1 on: April 15, 2018, 06:47:45 PM »
sounds like your machine is interpreting the Gcode in mm when the Gcode was composed in inches.
That makes the part come out 1/25th of the correct size.
Read up about G20/G21
« Reply #2 on: April 20, 2018, 03:30:40 PM »
i have read up on g20-G21, just not sure where i should go from there. Everything that i have made has been in inches (G-20) just not sure where i go to fix this issue.
thank you for you patients.
Eric
G-20,G21 issues
« Reply #3 on: April 20, 2018, 03:43:44 PM »
I am having problems as of late with the size of my work, for the last 2 months everything has been cutting really good now is cutting everything really small. i have been told it has something to do with G20, G21 g-code but have no idea how to fix the problem.
here is the start of one of my cuts:
G20 G90 G40
(follow path 1)
G0 Z0.5
T0 M6
G17
M3
G0 X-1.4332 Y-1.3777
G1 Z-0.0016 F30
G2 X-1.4372 Y-1.3706 I0.029 J0.0213 F60
G2 X-1.4468 Y-1.3458 I0.3526 J0.1512
G2 X-1.4551 Y-1.3204 I0.592 J0.2065
G2 X-1.4631 Y-1.2918 I0.7442 J0.2245
G3 X-1.475 Y-1.2506 I-0.8318 J-0.2166
G3 X-1.4831 Y-1.2284 I-0.248 J-0.078
G3 X-1.494 Y-1.2084 I-0.1018 J-0.0425
G3 X-1.4998 Y-1.204 I-0.0094 J-0.0064
G3 X-1.5056 Y-1.2055 I-0.0017 J-0.0053
G3 X-1.5137 Y-1.2185 I0.0273 J-0.0261
G3 X-1.5187 Y-1.2357 I0.1152 J-0.0425
G3 X-1.525 Y-1.2718 I0.5052 J-0.1066
im at a loss
« Reply #4 on: April 20, 2018, 03:49:05 PM »
if you put a line in your Gcode file right at the top G20. Then try running the file.
« Reply #5 on: April 20, 2018, 04:45:10 PM »
hello Craig,
i tried adding G20 to the top of the code and got the same results :/
here is what I have for the start of my code:
G20
G20 G90 G40
(follow path 1)
G0 Z0.5
T0 M6
G17
M3
G0 X0.1766 Y4.2419
G1 Z-0.025 F30
G3 X-0.4634 Y4.2397 I0.0692 J-115.6767 F60
G3 X-0.7585 Y4.2362 I0.1508 J-24.5929
G3 X-0.907 Y4.2326 I0.2237 J-12.337
G3 X-0.9847 Y4.2293 I0.1022 J-3.3855
G3 X-1.023 Y4.2269 I0.0989 J-1.8601
G3 X-1.0453 Y4.2249 I0.0465 J-0.6293
G3 X-1.0669 Y4.2217 I0.0332 J-0.3028
G3 X-1.0737 Y4.2197 I0.0058 J-0.032
hope this helps a little lol
« Reply #6 on: April 20, 2018, 04:53:42 PM »
the second line of Gcode is:
Code: [Select]
G20 G90 G40
Note there is a G20 already in it. Therefore your additional G20 which preceeds it is not required, it wont do any harm, G20/G21 are 'modal', they stay in
effect until deliberately changed.
Can you post the complete Gcode file as an attachment ( use "Additional Option....' just to the left of the text input panel).
« Reply #7 on: April 20, 2018, 05:19:13 PM »
i have attached the file
« Reply #8 on: April 20, 2018, 05:25:57 PM »
just FYI i have tried about 10 dif files and the same results
« Reply #9 on: April 20, 2018, 06:04:43 PM »
I downloaded the file and opened with Mach3 and it seems to work. I end up with a roughly rectangular part about 3 inches by 4 inches.
I've attached a pic of the part in my CNC viewer.
