Hello Guest it is November 10, 2026, 02:28:53 AM
Author Topic: VB / LUA evaluation- no license key  (Read 20218 times)
Offline TPS
  •  2,627 2,627
Re: VB / LUA evaluation- no license key
« Reply #10 on: April 06, 2018, 07:45:35 AM »
ok ,sorry.
« Reply #11 on: April 06, 2018, 09:03:16 AM »
Pretty sure I am in correct directory - get syntax errors with syntax errors infile and none when I remove them.
I parked this problem for a bit - glad to hear the feedback  on LUA and MACH4, might move towards there.
Offline TPS
  •  2,627 2,627
« Reply #12 on: April 06, 2018, 09:41:47 AM »
i have tested this code here:
Code: [Select]
tool = GetSelectedTool()
Dim UsersName As String
UsersName = AskTextQuestion("Please enter your name:")
Message "Please change tool now" & UsersName & "!"
MsgBox "Current tool at start of change is "    & GetSelectedTool()
SetCurrentTool( tool )
run fine.
post a copy of your M6Start as an attachment, probably there are characters you do not see
in a normal text Editor.
