Hello Guest it is November 10, 2026, 02:26:35 AM
Author Topic: VB / LUA evaluation- no license key  (Read 20214 times)
« on: April 05, 2018, 06:44:11 AM »
I want to develop some customization for my router setup. So that means MACH4 with LUA or MACH3 with VB. I am unsure which and wanted to try both before comitting.
Is there a list of restrictions - I know some - 500 line limit, no THC in plasma.
Will MACH3 allow me to run VB macros without a license ?
 I tried some M6 tool changes and the pop up AskTextQuestion or msgBox to M6Start.m1s  I added do not appear to pop up .. but MACH did stop and Cycle Start button continued the program.
I also noticed I could not add the tool change position to the GUI .
I did get notified of some errors too, which I corrected - but still no execution of the VB lines.
Offline TPS
  •  2,627 2,627
Re: VB / LUA evaluation- no license key
« Reply #1 on: April 05, 2018, 07:03:16 AM »
Mach3 will run VB in demo.
post your code, and we will see.
« Reply #2 on: April 05, 2018, 07:45:32 AM »
How do you have tool changes in General Config? That has an effect on which M6 macros run.
« Reply #3 on: April 05, 2018, 01:38:06 PM »
likewise Lua runs, in fact Mach4 is fully configured in Demo mode. It will run for about 6 minutes before it needs to be reset.
THC is enacted by the motion controller not Mach and to my knowledge Vital Systems Hicon board is the only Mach4 controller that has THC support
at the moment. Warp9's ESS board has most of the code needed for THC but is not ready yet, we've been waiting a year for it.
« Reply #4 on: April 05, 2018, 05:43:00 PM »
Thanks for the confirmation..
I found my macro files had a mix of UNIX and windows line endings.. I have been editing a few for a while I note the error is not explicit every time it happened- need to back track and fix my line endings.
Settings has Tool change pos of 0,0,0  which I cant appear to edit..
In General Config 'Tool Change' is 'Stop Spindle wait for cycle start'
I was trying to see if some popup would appear as part of the MACRO M6Start.m1s. However nothing appears. And program continues when I press cycle start.
tool = GetSelectedTool()
Dim UsersName As String
UsersName = AskTextQuestion(“Please enter your name:”)
Message Please change tool now, “ & UsersName & “!”
MsgBox “Current tool at start of change is “    & GetSelectedTool()
SetCurrentTool( tool )
« Reply #5 on: April 05, 2018, 06:11:26 PM »
I personally found that VB was troublesome in that errors were not consistent. It was that inconsistency
that induced me to go to Mach4, I mean if I'm going to learn something new it might as well be the
best for addressing my current and future needs, ie Mach4/Lua.
« Reply #6 on: April 05, 2018, 06:36:23 PM »
Are you sure you are editing the right macro? Meaning in the correct folder?
I haven't had any issues with VB macros like Craig is talking about, and have a few thousand people using the macros in my screenset.   ;)
« Reply #7 on: April 05, 2018, 07:53:35 PM »
I should perhaps explain a little better, it rather sounds like my comment indicated that VB doesn't work or work well.
That is not the case, as ger21 points out he has many VB scripts working well.
I was at that time still using Mach3 and just starting to write my own scripts. There are a number of things which I found frustrating,
the apparent plethora of 'standard means' of addressing Mach variables, inconsistent syntax conventions within CE and what I
still regard as a poor mechanism for repeating scripts, aka the macro pump.
While some of these gripes are in fact nothing to do with VB, they  combined meant a frustrating experience trying to generate
code. They could and probably should be regarded as 'learning pains' rather than any true fault.
Given that I already had a Mach4 licence I decided that it made sense to invest the learning effort in Mach4/Lua as it is a better
fit with future needs. I must point out the the learning curve of Mach4/Lua is worse than Mach3/CE. The results however
are a quatum leap ahead. If you are a reluctant programmer stay away from Mach4, if however you like a programming challenge
then Mach4 is just the ticket.
Offline TPS
  •  2,627 2,627
« Reply #8 on: April 06, 2018, 01:18:51 AM »
you have to enable Auto Tool Changer, then M6Start and M6End will be executed.
« Reply #9 on: April 06, 2018, 05:37:15 AM »
That's not correct.
Stop Spindle, wait for cycle start will run M6 Start, then M6End AFTER Cycle Start.
Automatic Toolchanger runs M6Start Only.
Ignore tool changes runs no macros.
