Hello Guest it is November 10, 2026, 02:30:35 AM
Author Topic: centerpiece full (change)  (Read 29628 times)
Re: centerpiece full (change)
« Reply #10 on: April 06, 2018, 10:24:58 AM »
same problem
Offline TPS
  •  2,627 2,627
« Reply #11 on: April 06, 2018, 10:30:31 AM »
courious, because the messagebox Shows only the coordinates where the probe was hit and the Diameter of the probe.
from the data it Looks like 70mm not 80mm  ???
when you watch axis dro's are they about +- 38mm when the probe is hit ?
« Last Edit: April 06, 2018, 10:34:05 AM by TPS »
« Reply #12 on: April 06, 2018, 01:37:28 PM »
the round is 80 mm I enclose photos
1 photo of the round
2 probing with last macro
3 probing with macro just modified, probe and '6mm (I set half as photo) Reply # 1 on: April 05, 2018, 12:40:44 AM
Offline TPS
  •  2,627 2,627
« Reply #13 on: April 07, 2018, 02:22:38 AM »
ok i have tested the following code here on my machine,
and it showed allway the correct diameter, did about 10 runs.
Code: [Select]
Rem VBScript To center probe outside diameter Metric Version
Speak (" psizionarsi CINQUE millimetri sopra il pezzo") 'Avviso Vocale
response = MsgBox ("   5 mm    SOPRA IL PEZZO")
Sleep (1000) ' pausa di 1 secondi
Speak (" CONFERMARE centro pezzo pieno") 'Avviso Vocale
Message "INIZIO CENTRO PEZZO PIENO"
response = MsgBox ("CONFERMARE CENTRO PEZZO PIENO")
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(43) 'gets the current tool diameter
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Call ProbeGrounded()
    Exit Sub
Else
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    OutsideDiameter = GetUserDRO(1152)
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    While IsMoving ()
    Wend
    Call SetDro (0,0.000)
    While IsMoving ()
    Wend
    Call SetDro (1,0.000)
    Code "F50" 'slow feed rate to 100mm/sec
    Code "G90 G0 X" &XNew + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Left
    XNew = Xcurrent - OutsideDiameter * .6
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G91 G0 X2"
    Code "G91 G0 Z10"
    Code "G90 G0 X" &XCurrent 'rapid move back to start point
    Code "G91 G0 X" &XCurrent - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Right
    XNew = XCurrent + 75 'probe 75mm to right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    Code "G91 G0 X-2"
    Code "G91 G0 Z10"
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G90 G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Code "G90 G0 Y" &YNew - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe up
    YNew = YCurrent + 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos1 = GetVar(2001)
    Code "G91 G0 Y-2"
    Code "G91 G0 Z10"
    Code "G90 G0 Y" &YCurrent
    Code "G91 G0 Y" &YCurrent + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe down
    YNew = YCurrent - 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos2 = GetVar(2001)
    Code "G91 G0 Y2"
    Code "G91 G0 Z10"
    YCenter = (YPos1 + YPos2) / 2
Rem move To the center
    Code "G90 G0 Y" &YCenter
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Call SetUserDro (1152,YPos2 - YPos1 - CurrentToolDiameter)
MsgBox "diameter: " &GetUserDro(1152) &" mm"
    Code "G4 P0.25"
    Code "F" &CurrentFeed 'restore starting feed rate
   Call ReturnG90G91State()
   Exit Sub
End If
Sub ProbeGrounded()
   Code "(Probe plate is grounded, check connection and try again)"
End Sub
Sub ReturnG90G91State()
   If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
      Code "G91"
   End If
   If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
      Code "G0"
   End If
End Sub
« Reply #14 on: April 07, 2018, 03:55:36 AM »
tried the macro, same problem maybe I have some wrong setting. when I use it I divide (: 2) the probe !! thanks for the patience TPS !!!
Offline TPS
  •  2,627 2,627
« Reply #15 on: April 07, 2018, 04:02:48 AM »
if you push your probe by Hand, is it switching imediately, or maybe after 3mm push ?
Offline TPS
  •  2,627 2,627
« Reply #16 on: April 07, 2018, 04:04:28 AM »
you can also try to replace
this code:
by:
   Call SetUserDro (1152,YPos2 - YPos1 - (CurrentToolDiameter/2))
« Reply #17 on: April 07, 2018, 04:58:14 AM »
the switching is immediate, also tested with another probe, the change does not work.
Offline TPS
  •  2,627 2,627
« Reply #18 on: April 07, 2018, 09:36:47 AM »
i have tested the code from reply #13 again.
it is working perfect here,
so i am out of ideas. sorry.
« Reply #19 on: April 08, 2018, 03:36:50 AM »
good morning
TPS, I documented (in my small) I solved by replacing OEM code fuction 221 with 1000 (I saw 1024.set) then in the macro I replaced:
CurrentToolDiameter = GetOemDRO (43) 'gets the current tool diameter
with
CurrentToolDiameter = (GetOEMDRO (1000) / 2) 'gets the current tool diameter
it works well, I wanted to ask you (of VB I do not understand almost anything !!) if it is done well or if it is dangerous.
