Hello Guest it is November 10, 2026, 01:54:45 AM
Author Topic: work break button  (Read 10018 times)
work break button
« on: March 26, 2018, 04:32:53 AM »
buongiorno
e' fattibile un pulsante  script per la pausa lavorazione?
mi spiego a meta' lavorazione metto in pausa premo il pulsante e lui memorizza in un file dove si e' arrestato ( riga=xx , x=xx , y= xx , z=xx ).
  •  9,376 9,376
Re: work break button
« Reply #1 on: March 26, 2018, 06:26:12 AM »
@ Brillo1959,
Vuoi imparare come farlo da solo o vuoi semplicemente che gli altri scrivano il codice per te?
« Reply #2 on: March 26, 2018, 07:32:03 AM »
thanks Tweakie for the answer
I would (if possible) that someone wrote it, I would not be able to,
regards
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 26, 2018, 11:18:59 AM »
code for the button to get a filname where to write to:
Code: [Select]
'get the filename for digfile from user
Sub Main()
 If NOT Isloading() then
Dim  FNum, FName ' Declare variables.
'get Filename from user
Begin Dialog TextBoxSample 16,30,180,96,"enter digfilename"
OKButton 132,20,40,14
Text 8,8,132,8,"filename without extension:"
TextBox 8,20,100,12,.TextBox1
Text 8,44,132,8,"file will be in c:\Mach3\GCode"
End Dialog
Dim Dlg1 As TextBoxSample
Dialog Dlg1
SetUserLabel(255, Dlg1.TextBox1)
'open the to file errase all existing data
FNum = FreeFile ' Determine next file number.
FName = "C:\Mach3\GCode\" + GetUserLabel(255) + ".nc"
Open FName For Output As FNum ' Open file.
Close ' Close all files.
SetUserDro(1166,1)
   End If
End Sub
code for the button witch saves the actual coordinates:
Code: [Select]
Sub Main()
'wait for axis standstill
WaitForMove
'open the file for output data data
Open FName For Append As FNum ' Open file.
Print #FNum, cStr(GetDro(0)) & "," & CStr(GetDro(1)) & "," & CStr(GetDro(2))
End Sub
'global Sub's
Sub WaitForMove ()
While IsMoving()
Sleep(5)
Wend
End Sub
what you realy looking for is digitizing.
digitizing wizard and search function is your friend.
« Reply #4 on: March 26, 2018, 11:56:49 AM »
thanks for the TPS answer (kind as always)
what I would like to do is this:
1 gcode load
2 start of processing
3 break (if the processing is long)
4 press the button and at this point I should store in file 1 the line where I stopped and the coordinates, to continue (hypothesis) the day after
I do not know if it's possible, I repeat VB I do not understand!
Offline TPS
  •  2,627 2,627
« Reply #5 on: March 26, 2018, 01:02:19 PM »
and what is about:
-doing a new refernce ?
-knowing where you have stopped your gcode file (power off)
what you are planning is not done with pushing a button and running a script.
« Reply #6 on: March 26, 2018, 03:30:36 PM »
it is exact in the file I would like to save where I interrupted the execution of the gcode, it would be enough for me to save the row number I attach photos to make me understand
