Hello Guest it is October 23, 2026, 05:16:25 PM
Author Topic: How to Install an auto tool changer  (Read 9050 times)
« on: March 25, 2018, 11:38:41 AM »
Hi there
I am trying to Install a CC Auto tool changer Spindle Model (MHS72-7512FSF).
What I like to know is What hard ware do I need to have? , and what steps do I need to take in order to do so?
Please be noted that this my first attempt to install a Spindle with ATC, I installed a Manual spindle before, BUT ATC I am a Newbie.
Regards
Jhonansaro
Offline TPS
  •  2,627 2,627
Re: How to Install an auto tool changer
« Reply #1 on: March 26, 2018, 11:21:27 AM »
-some toolholdes
-a solinoid valve for the tool clamp
-a macro
-a couple of other things to get everything fixed
- some luck
« Reply #2 on: March 26, 2018, 12:12:04 PM »
Hi TPS
Thanks for the reply.
I sort of know about them.
But could you explain with a little more detail.
I  know that there is a Start and stop Macro, I already have the "M6Start" file, Do i also need a stop Macro? or is it in my Start macro already?
also I think I need  to add some Tab pages to my Mach3, Do you have the links for them?
My Spindle should have the required Solenoid, I am planning to use CC (Chinese) or HSD (Italian)
Regards
Jhonansaro
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 26, 2018, 12:58:57 PM »
this is a Standard Start macro. you will need a machine specific one, like i have done here:
http://www.machsupport.com/forum/index.php/topic,36417.0.html
BTW the search function of the Forum is not so hard to understand ;)
the stop macro is only to return where the tool Change started.
ok the only Thing, i think, is that you please read a Little bit more about basic's  of ATC
that is a Point YOU have to figure out.
