Hello Guest it is October 24, 2026, 05:53:04 PM
Author Topic: Mach 4 scaling and keyboard button mapping  (Read 32242 times)
Re: Mach 4 scaling and keyboard button mapping
« Reply #20 on: September 08, 2022, 05:29:12 PM »
Hi chuck,
my profile, or more technically correct, screenset never had a DRO for scaling, I always used G50 and G51 for scaling whenever I've needed it.
Over the last couple of years my screenset has changed as I've built a new machine, much bigger, more powerful and more rigid, using servos
rather than steppers, and so I rather doubt my screenset is of any particular use to you.
What I have found is that my screenset is 99.99% standard as shipped by NFS....all I've really added are those specific features I need for my machine,
things like individual alarm inputs for each servo, and the inputs for a wired pendant for example. All and anything I can possibly require is already built into Mach4.
« Reply #21 on: September 08, 2022, 06:25:52 PM »
Thanks for the reply Craig,
For some reason I thought you sent me a profile that included scaling like in Mach3 two years ago.
I apologize, my memory apparently isn’t very good.
I will end up doing as you are doing with G50 & G51
Again I apologize for my poor memory and thanks again for responding to me.
Chuck
« Reply #22 on: September 08, 2022, 06:44:06 PM »
'the good thing about Alzheimer's is that your always meeting someone new.'
« Reply #23 on: September 08, 2022, 06:56:37 PM »
Right on, and I like the part where you can read the same good book more than once   😊
FYI, the machine I converted was a Shizoka mill master, 28 inch X travel with FANUC servos
« Reply #24 on: September 08, 2022, 07:07:12 PM »
kool, a very substantial machine!
« Reply #25 on: September 08, 2022, 11:10:39 PM »
Yes very substantial, it weighs in at 11,000 pounds.
In addition to milling I installed a 180W CO2 laser on it and I can also do plasma cutting with it.
