Hello Guest it is October 25, 2026, 01:58:22 AM
Author Topic: Laser tool measuring  (Read 6422 times)
« on: March 19, 2018, 08:24:38 PM »
I got this crazy idea the other day to try building a DIY laser tool measuring system. A quick search of the Internet showed that commercial solutions were in the thousands of dollars, and only one guy on Youtube has a working DIY example. I found the laser sensor he is using on Ebay for $75.  Now it's in my shop and I have to make good on the attempt. Anyone else tried doing this? Anyone got any advice?
Measuring tool length should be easy, use the same procedure as with a touch plate. The diameter may be a bit more difficult. Cutters are not always symmetrical within the volume of their rotation. I figure I would need to spin the tool to get an accurate measurement. This would avoid with asymmetry  and would only require measuring laterally from one direction.
Edit: I forgot to mention that it has a 80mm throat opening and is repeatable within 5μm. It takes 10v to 30v DC and acts a PNP switch.
-Freeman
« Last Edit: March 19, 2018, 08:31:50 PM by Analias »
I'm not a complete idiot...
    there are some parts missing.
Re: Laser tool measuring
« Reply #1 on: March 20, 2018, 12:09:43 AM »
Just use its signal as a probe input then use the Touch button to run the mcTouchOff module. Adding a spin reverse for diameter measurements to the module for yourself shouldn't be too difficult.
  •  9,374 9,374
« Reply #2 on: March 20, 2018, 07:09:30 AM »
Hi Freeman,
Please keep us posted on how this pans out - sound like an excellent solution.
