Hello Guest it is November 07, 2026, 10:40:00 AM
Author Topic: LazyCam 2.02  (Read 11147 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
LazyCam 2.02
« on: July 12, 2007, 09:45:32 PM »
Hi, Art & Brian
Very Very Nice, My small airfoil/spilins now load's with .001, Conn.
line Toll. and Offset Properly, Nice and smooth.
Inside/Outside working Correct hear on this one now.
There are 4 that Did Offset before, But not now, See Below, Dxf Also.
The airfoils/splines were the bigest problem for Me.
Rapids for Arc's Don't change end's when moved.
Rapids for Lines Do change now, Maybe thy did before, Not sure.
Art, The "UN-Group" I Was talking about (Previous Yahoo Post), I think,
Would allow some of us to generate Lathe G-code.
Not trying to Un-group a Square/Closed Chain, Just a Line-Arc-Line Caine.
If you'd PM your PH #, I could probable better explain my thought's on this.
Any Way, Were Putting Together a Collection to Re-Attachl all that Pulled Out Hare, Save It,(;-}}.
Thank So-Much, Chip
« Last Edit: July 13, 2007, 01:04:13 AM by afn09556 »
Offline Chip
  •  2,055 2,055
Re: LazyCam 2.02
« Reply #1 on: July 13, 2007, 01:34:17 AM »
Hi, Art & Brian
The view Outside Offset, Wouldn't offset the top shape by it's self or with all selected.
Circle top offsets wrong.
Square doesn't offset top right corner
Inside Offset View, Circle off, Wouldn't offset the top shape by it's self or with all selected, Square Looks OK
Another example, Chip
« Last Edit: July 13, 2007, 01:43:42 AM by afn09556 »
Offline Chip
  •  2,055 2,055
Re: LazyCam 2.02
« Reply #2 on: July 13, 2007, 02:11:56 AM »
Hi, Art & Brian
Just some more.
Thanks, Chip
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyCam 2.02
« Reply #3 on: July 13, 2007, 12:52:30 PM »
Chip:
 I had a tolerance set too severe in some offsetting, so redownload the updater.. may or may not fix your current trouble..
Art
Offline Chip
  •  2,055 2,055
Re: LazyCam 2.02
« Reply #4 on: July 26, 2007, 08:06:37 AM »
Hi, Art & Brian
Still having problems with Arc's, End points not being respected by LCam.
Hears the Dxf and LCam files.
Using .000001 Con. load toll., seems best, In-Out's backwards hear.
Square outside offset above doesn't close upper right corner.
Thanks, Chip
« Last Edit: July 26, 2007, 08:51:47 AM by afn09556 »
