Hello Guest it is October 01, 2026, 12:21:13 AM
Author Topic: meters stopped working  (Read 6761 times)
« on: March 14, 2018, 04:09:51 PM »
I had a great setup with several meters displaying voltages from 4 analog inputs.  I was changing the ticks and max value on one of the meters and they all stopped working.  Then I reverted back to the original settings but no matter what I do, the meters are silent.  However, one meter showing an average/sec of voltage is working fine.  The registers for these analog inputs show the proper voltages.  I have the code in the PLC script and was wondering "are if then statements in the PLC a problem"?  Would it be better to do this in the signal script?  Does the signal script scan just like the PLC so I could basically use the same code there?
Re: meters stopped working
« Reply #2 on: March 14, 2018, 04:55:57 PM »
Yes that was my posting to set this all up but now it has stopped working for no apparent reason...
« Reply #3 on: March 14, 2018, 05:56:41 PM »
Fixed it!  Just during a copy the meter names changed...  escy fix difficukt to see
