Hello Guest it is October 10, 2026, 10:57:16 PM
Author Topic: laser / web centering  (Read 7251 times)
« on: March 09, 2018, 12:42:09 PM »
http://www.machsupport.com/forum/index.php
Speak ("confermare ZERO PEZZO LASER") 'Avviso Vocale
Message "************  INIZIO ZERO PEZZO LASER ************"
Sleep (1000) ' pausa di 1 secondi
response = MsgBox ("CONFERMARE ZERO PEZZO LASER")
SetUserLED(1103,1) 'close Klause's video window
Call SetOemDRO(3,80) 'reset jog rate to 80%
Xs=GetOemDRO(59) 'read Xscale DRO
Ys=GetOemDRO(60) 'read Yscale DRO
Xmove = -167.890 'enter your camera offset here
Ymove = -46.160  'enter your camera offset here
Code "G91 f500 X" &Xmove & "Y" &Ymove 'make incremental move
While IsMoving () 'wait while that happens
Wend
Code "G90" 'go back to absolute moves
DoOEMButton (1008) 'zero X axis DRO
DoOEMButton (1009) 'zero Y axis DRO
Code " (   HOMING CENTRO COMPLETATO)" 'message for status bar
Speak ("homing centro completato") 'Avviso Vocale
I would like if possible to choose whether to go to the center with laser or web, currently I have two buttons one for laser one for web as the coordinates change
Re: laser / web centering
« Reply #1 on: March 09, 2018, 02:19:17 PM »
I have two buttons one for web center one for laser center I would (if possible) put them in one and choose which one to use, since they change the coordinates
1 botton laser
Speak ("confermare ZERO PEZZO WEB") 'Avviso Vocale
Message "************  INIZIO ZERO PEZZO WEB ************"
response = MsgBox ("CONFERMARE ZERO PEZZO WEB")
Xmove = -140.000 'enter your camera offset here
Ymove = -32.700 'enter your camera offset here
Wend
2 botton web
Xmove = -130.000 'enter your camera offset here
Ymove = -25.700 'enter your camera offset here
Wend
Offline TPS
  •  2,627 2,627
« Reply #2 on: March 10, 2018, 07:09:25 AM »
this should do what you want
Code: [Select]
Sub Main
  Begin Dialog SelectCentering 31,32,125,96,"Select Centering"
OKButton 20,68,40,14
CancelButton 70,68,40,14
GroupBox 20,8,72,52,"centering",.GroupBox1
OptionGroup .OptionGroup1
OptionButton 26,24,54,8,"laser",.OptionButton1
OptionButton 26,40,54,8,"web"  ,.OptionButton2
  End Dialog
  Dim Dlg1 As SelectCentering
  Button = Dialog (Dlg1)
  If Button = 0 Then Exit Sub
  Selected  = Dlg1.OptionGroup1
  'laser is selected
  If Selected = 0 Then
Wend
  End If
  'web is selected
  If Selected = 1 Then
Wend
  End If
End Sub
« Reply #3 on: March 10, 2018, 09:15:52 AM »
perfect !!! it works very well.
TPS you are a GREAT !!!!!! thanks for your help and patience ;) ;) ;)
