Hello
Guest
it is
November 21, 2026, 01:05:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Motor Configuration Problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Motor Configuration Problem (Read 15131 times)
Mauri
328
Re: Motor Configuration Problem
Reply #10 on:
March 10, 2018, 12:30:01 PM »
cv580,
Mach4-3481_Integra_Plugin_2.01.72.zip
Load both the Firmware and Mach4 Plugin.
Use VSI Device Manager to install Firmware.
Read the Manual provided on how to install.
http://www.vitalsystem.com/portal/motion/VSI_Device_Manager_Manual.pdf
Mauri.
Logged
cv580
53
Reply #11 on:
March 10, 2018, 12:58:05 PM »
loaded the Mach4-3481 plugin and firmware as Mauri suggested, everything is working now with Mach4
Thanks for your help
Logged
Print
Pages:
1
2
Go Up
« previous
next »
