Mach Discussion => Mach4 General Discussion => Topic started by: cv580 on March 07, 2018, 10:19:49 PM
Fresh install of Mach4 and I am not able to enter any motor tuning info into the Counts per Unit, Velocity, Acceleration, G Force, Backlash, Reverse, Enable Delay, boxes as they are all greyed out for all motors selected on the Motor Config page, not able to config any of the motors?
On the axis mapping page I am only able to choose motor6 or motor7 for a slave motor on the drop down menu, not able to enter any other motor as a slave?? I want to set motor5 as a slave motor.
Has anyone come across these issues ?
what is your active motion controller? Sounds like you don't have one at all.
I am using the HiCON Integra controller, I can get motor movement in the test motion section of the HiCON plugin. Mach4 will not let me enter any info on the motor config page.
I'm not familiar with the Hicon, I use an ESS.
When configuring the ESS it also makes assignments in Machs core plugin as well. I suspect that the settings you wish to make should be done
in the Hicon plugin and it will set certain items within Machs core.
In the motor tuning tab of the configuration dialog, select the motor on the right first. Just click on one. Not the check box, but the item itself.
Steve
You'll also want to double check that the motors are enabled in your Axis mapping page. You should be able to choose any motor to use as a slaved axis, as long as it is not already selected for another axis.
-Bryanna
Thanks Steve & Bryanna your info has helped.
I had this problem weeks back you need to make sure you have the latest firmware in the hilcon ask vitalsystem if your using the new mach 4 v2 I uploaded my firm ware and the motors worked
and the homing problem also worked I did have a few settings wrong vitalsusyems accessed it throught the internet and fixed it quick call them
cv580,
Also you need to download all the documentation that on HiCON that they provide, it shows all the settings required to make it work.
Backlash settings are set on the HiCON configuration and work fine.
You are able to setup 6 Axis with the HiCON card we have 4.
We have setup Soft and Hard limit switches and all work fine.
We also can fully control Mach4 from the Controller via button control via the HiCON card.
We have our MPG directly connected to HiCON and it work perfectly.
Our HS Spindle is also controlled via the HiCON card.
The Vital systems company has great support, via Phone, Email, Mach4 Vital System Forum and also via direct connection to your computer.
Current Mach4 V3481 with HiCON V3481 firmware/plugin are rock solid.
You can also use later version of firmware but only use the same Version of plugins as Mach4.
Mauri
Mauri
Which version of HiCON plugin 3481 do you recommend as I see two different HiCON version3481 plugins on their download page. I assumed the latest plugin would be the one to use so that is what I have been trying to make work (version 3663), I will try the one you recommend. Nothing in their documentation about this!
cv580,
Mach4-3481_Integra_Plugin_2.01.72.zip
Load both the Firmware and Mach4 Plugin.
Use VSI Device Manager to install Firmware.
Read the Manual provided on how to install.
http://www.vitalsystem.com/portal/motion/VSI_Device_Manager_Manual.pdf
Mauri.
loaded the Mach4-3481 plugin and firmware as Mauri suggested, everything is working now with Mach4
Thanks for your help
