Hello Guest it is November 22, 2026, 01:43:58 PM
Author Topic: mach 4 plasma tool off set  (Read 13887 times)
« on: March 04, 2018, 11:06:52 AM »
can some one tell me how do I add a tool to my plasma  mach 4  I running a vitalsystem arch pro screen I want to add an engraver.   I see there are tools  would I use them and setup the offsets.  program a button.  and assign an mcode to use in sheet cam.  im not sure  thanks jeff c
Re: mach 4 plasma tool off set
« Reply #1 on: March 10, 2018, 06:18:32 PM »
im happy to report  my vital system hilcon controller and arch pro plasma screen can now change tools . with the m6 command  thanks to  Cbyrdtopper  who did the code  I will say I learned a lot
of how things work in mach 4    now when activating a code in sheet cam my  x y z now responds to the tool offset triggers an out put  and has a button for over ride
and works fine   now I have the ability to have 99 tools  don't need that many in plasma lol
« Reply #2 on: March 26, 2020, 10:48:05 AM »
It's been a while on this thread, but can you post the code that I sent you?  I don't remember how I helped you out and someone else is asking about this as well.
Thanks!
Chad Byrd
