Hello Guest it is October 21, 2026, 10:50:10 AM
Author Topic: How to setup port and pins and stuff.  (Read 10981 times)
Re: How to setup port and pins and stuff.
« Reply #1 on: February 27, 2018, 09:10:06 PM »
what sort of controller? I don't think I've ever seen anything quite like that.
Need to know:
1) What PC and OS?
2) What controller (parallel port or otherwise)?
3) What stepper drivers?
« Reply #2 on: February 28, 2018, 05:18:56 PM »
Need to know:
1) What PC and OS?
HP Pavilion TS 15 notebook, Windows 10 x64
USB?
no clue?
« Reply #3 on: February 28, 2018, 05:34:02 PM »
given that you have a laptop running a 64 bit OS then you MUST have an external motion controller,
a parallel port wont work.
I need more info, what controller?
Do you have manufacturers documentation?
I don't do 'crystal ball'.
« Reply #4 on: March 18, 2018, 02:26:18 PM »
GRBL 0.9J,USB port cnc engraving machine control board, 3 axis control
Connection: USB (USB-CH340)
Software: GRBL controller, UniversalGcodeSender
Input voltage: 12-36V
Master chip: atmel 328P (arduino nano)
Stepper motor driver: A4988
Spindle drive chip: MOSFET (recommendation 12~36V, current : within 10A )
Spindle PWM speed: Support
Support stepper motor: 12V, maximum current of 2A or less is recommended within 1.5A and additional heat. (Any stepper motor 42, 57)
Laser engraving: Support
Power Interface: 5.5-2.5mm DC interface
« Reply #5 on: March 18, 2018, 04:22:39 PM »
looks like you have  GRBL controller. This is a Mach forum and I doubt you'll find any information of use for
such a controller.
May I suggest having a look at YouTube at both Mach3 and GRBL clips, you may note the differences.
Mach is useful for large machines in a way that GRBL is not.
