Hello Guest it is November 21, 2026, 10:37:25 AM
Author Topic: Tools led  (Read 6474 times)
Tools led
« on: February 24, 2018, 12:10:04 PM »
Hello,
can someone please help me with the code bellow. I have two led's on my screen named T01LED and T02LED and I want them to light up when tool number changes. I've put this code in PLC but it doesn't work. Thanks.
local currenttool = mc.mcToolGetCurrent(inst)
if (currenttool == "1") then
scr.SetProperty("T01LED", "Value", "1")
     else
         scr.SetProperty("T01LED", "Value", "0")
end
if (currenttool == "2") then
scr.SetProperty("T02LED", "Value", "1")
     else
         scr.SetProperty("T02LED", "Value", "0")
end
Peter
Re: Tools led
« Reply #1 on: February 24, 2018, 01:05:47 PM »
You need to change 1 thing and it will work.
if (currenttool == 1) then         Don't put the numbers in  " ".
if (currenttool == 2) then
I put tested this code in the PLC script and it works just fine. =)
     scr.SetProperty("TestLED", "Value", "1")
else
     scr.SetProperty("TestLED", "Value", "0")
end
Chad Byrd
Re: Tools led
« Reply #2 on: February 24, 2018, 01:41:49 PM »
Thank you very much for that. I knew that was something simple. It work now thanks again.
Peter
