Hello Guest it is November 13, 2026, 01:22:11 PM
Author Topic: Z axis stopped working  (Read 12269 times)
« on: February 19, 2018, 05:48:01 AM »
Everything was working fine through several runs and then the z axis stopped working properly. x and y still work fine. I just replaced the power supply and this fixed it before. On the ports and pins page z axis is checked. Am I missing something?
Re: Z axis stopped working
« Reply #1 on: February 19, 2018, 06:15:48 AM »
is the Z DRO still working?
Does your BoB have LEDs on the outputs and if they do are they working?
Could you swap the driver for say the X axis driver to see if the fault follows the driver?
« Reply #2 on: February 19, 2018, 03:17:07 PM »
Please see attached. The input signals current state number drops and then fluctuates. That's when it stops working.
« Reply #3 on: February 19, 2018, 05:02:50 PM »
thats an input, does it really matter?
Clearly whatever is taking the inputs offline is doing the same with the outputs.
Does the Z DRO still work?
What about the Bob, do the output LEDs still show signs of life?
What about the DriverTest.exe, what does it show?
« Reply #4 on: February 19, 2018, 06:07:13 PM »
 Z DRO still working?  Yes
Does your BoB have LEDs on the outputs and if they do are they working? Yes and yes
Could you swap the driver for say the X axis driver to see if the fault follows the driver? How do I do this?
« Reply #5 on: February 19, 2018, 09:40:01 PM »
are the drivers separate or all on one circuit board?
My suggestion is feed the Z axis step and dir pulses to the X axis driver and see how the X axis motor responds.
« Reply #6 on: February 20, 2018, 04:33:26 AM »
One circuit board. Now none of them work. x y z. >:(
« Reply #7 on: February 20, 2018, 03:49:22 PM »
Switched to standard PC and seems to be working ok now.
