Hello Guest it is October 25, 2026, 12:36:02 AM
Author Topic: PLC to start cycle and rewind g-code?  (Read 7761 times)
« on: February 17, 2018, 07:22:14 AM »
Hi All,
Is it possible to have PLC operate the cycle start, rewind and reset  functiions?
Splint
Re: PLC to start cycle and rewind g-code?
« Reply #1 on: February 17, 2018, 11:15:47 AM »
I'm not sure why, the PLC script runs every 10milliseconds or so, you don't think it might be a bit much to hit the cycle start button 100 times
a second?
« Reply #2 on: February 18, 2018, 04:02:38 AM »
I certainly wouldn't need a frequency that high, probably once every 10 seconds, if that. I was thinking of running a robot in a production environment, using a plc to have control of everything other than the robot then sending a start signal to mach to make the robot play its part. So this would be possible? I'm aware of the kinematics issues with mach and robots, I'm thinking of using the Jcode plugin to teach the robot.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: February 18, 2018, 04:29:20 AM »
You can do this with a dummy panel and wxTimer
Code: [Select]
TimerPanel = wx.wxPanel (wx.NULL, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxSize( 0,0 ) )
BotTimer = wx.wxTimer(TimerPanel)
TimerPanel:Connect(wx.wxEVT_TIMER,
function (event)
    -- send something to bot
-- process any returns from bot
BotTimer:Start(10000, true) --restart BotTimer if required
end)
BotTimer:Start(10000, true) -- start BotTimer on a RunOnce
DazTheGas
