Hello Guest it is November 13, 2026, 11:33:57 AM
Author Topic: Z speed limiting xy speed  (Read 23180 times)
« on: February 13, 2018, 07:25:53 AM »
Hi there,
I am using the Z pulses to drive a laser TTL trough a micro. So I really do not mind about how fast the Z speed is because there is no motor connected to it and I need it fast..
I have set x and y at 15000mm/min  (that's my max speed on these axis) and Z at 50000 mm/min. When I run the gcode with a feed rate of 1800 mm/min I expect z to be so fast that should not slow down xy.
I do not know why but z is slowing xy and it is running at merely 500-800 mm/min.
The situation does not change if I increase the feedrate. Mach3 is running at 75 kHz so this shlould not be the issue either. The Z acceleration is also very high (10000) so neither this is the issue.
I have tried different gcodess produced with different cam software but still, despite the settings, Z is slowing down XY which I can hear stepping all the time. I have set constant speed but the machine sounds like the gcode is running in exact stop.
I have attached the gcode I am using for the above test. As you will see the Z movement are from 0 to -1 mm so at the speet I have set the Z, I am not expecting xy to slow dons or to step..
Is there a setting to detach Z speed from xy? Any hint?
Thanks for helping,
Felice
Re: Z speed limiting xy speed
« Reply #1 on: February 13, 2018, 11:06:12 AM »
the X,Y and Z axes are coordinated and cant be detached from one another.
You could use the spindle, the spindle is an out-of-band axis. You can use step/dir pulses for a servo type spindle, you only need the step signal.
Also allows you to separately adjust the pulserate without affecting coordinated moves of the other axes.
« Reply #2 on: February 13, 2018, 12:16:59 PM »
Hi Craig,
thanks for your answer. I suspected that. I did try using the S vaules but was even worst. The machine was stepping all the time waiting for the S value to change.
I tought that using Z should have been much faster.
What I do not understand at present is why Z is so slow despite the very high performance I mentioned in my original post above.
Do you think is a problem generated by the gcode?
« Reply #3 on: February 13, 2018, 05:44:32 PM »
if I understand what you're trying to do is use the Z axis step pulses in some sort of frequency to voltage
conversion to control a laser?
Seems like a difficult way of doing it. The Z axis pulse rate will change at each move determined by the other
coordinated axes.
Using S commands wont work either as they are read per line, thus a move has to complete BEFORE the next
line and therefore the next S command can be read.
What you have to do is start the laser with an S command but the S (speed DRO or pound variable) will need to be updated
either by a brain or a macro at the macro pump rate.  At the macro pump rate the laser pulse stream can be
modified  ten times a second even during a coordinated move. Would that suffice?
My VB coding has never been strong, I converted to Mach4 and Lua, if I'm going to learn something new I wanted it to
be up to date, ie Lua. While I can see how I would go about coding this I'm not going to offer help to do it in VB.
If you wish to download Mach4 I could and would be keen to help you code it in Lua.
« Reply #4 on: February 13, 2018, 05:46:27 PM »
When moving 3 axis simultaneously the actual feed rate is along the vector between the 3 axis. So if Mach 3 sees the Z distance as a long move then motion along XY will be slowed a lot. Your Z move needs to be seen as very short by Mach 3. Maybe setting the step pulses per unit move to a very high number would do the job.
« Reply #5 on: February 19, 2018, 10:40:36 AM »
Thanks for your explanation. Actually the move in Z is maximum 0.5 mm and I did set the Z speed 20 times faster than the other two axis. I have 250 steps per mm on Z and 500 steps per mm on XY. But still the machine is slowing down and running in steps with a feed rate of 2000 mm/min rather than in a smooth linear motion. I am not sure if there is anything else I can set in Mach3 or in the Gcode to avoid this issue. I did also set G64 constant velocity but no changes.
Offline TPS
  •  2,627 2,627
« Reply #6 on: February 19, 2018, 12:05:48 PM »
steps per mm and Speed is one thing,
acceleration is an other Point.
i don't know the dimensions of your machine, but i would start with some test's
by entering command into mdi.
for example:
F500
G1 X500 -> measure the needed time
 F500
G1 Y500 -> measure the needed time
F500
G1 X500 Y500 -> measure the needed time
just to make sure not one of the 'major' axis are making the Limit.
then
F500
G1 X500 Y500 Z5 -> measure the needed time
to get a 'feeling' what is 'pushing' the brake.
Thomas
« Reply #7 on: February 19, 2018, 12:38:08 PM »
@TPS
Hi, thanks for your suggestion. Since the Z motor is disconnected because I am using such output to feed the laser board trough a microprocessor, I have set huge acceleration (100000),  but still Z is slowing down XY. Looks like doesn't matter how fast and reactive I make Z , when there is a change in Z, the other axis slow down for a fraction of second but slow down causing the machine to sound really hugly.  This does not happen with with X and Y if I make Z constand and change a value  in X or Y.
Offline TPS
  •  2,627 2,627
« Reply #8 on: February 19, 2018, 12:41:19 PM »
have you tryed "real" (x3) instead of "huge" values?
Offline TPS
  •  2,627 2,627
« Reply #9 on: February 19, 2018, 12:42:59 PM »
@TPS
can you please explain a Little bit, sorry my english is not good enough.
