Hello Guest it is September 30, 2026, 12:16:16 PM
Author Topic: VistaCNC P2-S malfunctioning with Mach4  (Read 22458 times)
Re: VistaCNC P2-S malfunctioning with Mach4
« Reply #10 on: February 09, 2018, 01:33:59 AM »
Hm.....
Removing unused plugins do help, but it seems not enough...
My P2-S became a brick again now....
Offline thosj
  •  542 542
« Reply #11 on: February 09, 2018, 07:47:24 AM »
Have you tried just removing the keyboard plugin from the plugins folder, or is that what you meant by unplug_plugin? Maybe it IS the keyboard plugin conflicting? I'll have to try that, I don't much like jogging with the keyboard anyhow, but I DO LIKE jogging with the P2-S, if/when it works. ;D
Tom
« Reply #12 on: February 09, 2018, 08:22:36 AM »
http://www.machsupport.com/forum/index.php/topic,32603.0.html
This is the link where you can find the plugin and video manual from DAZ the developer. ;)
I unplugged all the plugins that I don't use. But I think keyboard plugin made the conflict.
I'm not sure 100% yet, but it seems works, I only experienced a BRICK only once today. ;)
Offline thosj
  •  542 542
« Reply #13 on: February 12, 2018, 07:01:32 AM »
I removed the keyboard plugin from the plugins directory completely, restarted Mach4, and the P2-S still bricks at some point, seemingly, or usually, while running gcode!! So it isn't the keyboard plugin, I guess.
An interesting aside, even with the keyboard plugin NOT in the plugins directory, the little keyboard shows in the tray briefly before disappearing.
Tom
« Reply #14 on: February 12, 2018, 10:12:05 AM »
That might be Mach loads keyboard plugin at starting...
Try unpkugin_plugin by DAZ.
This will make Mach4 not even try to load the plugins.
In my case, Mach4 loaded duplicate keyboad plugins... so I had many icon in the tray... and when I move cursor on them they disappeared....
Mach4 seems to have some problem managing the plugins....
I haven't seen bricking for 3 days so far...
« Reply #15 on: March 01, 2018, 03:07:36 AM »
I thought my problem solved... but not...
I do want to know if there's anybody who doesn't suffer this trouble with P1-S, P2-S or P4-S etc... which has "Screen" on it.
This is very annoying...
I don't turn off the machine and the computer, but I have to... only because REVIVE VistaCNC hand wheel.....
« Reply #16 on: March 01, 2018, 03:20:04 AM »
I use Dell i5-2400S PC with Legit Windows 10 Pro.
I only installed Windows 10, Mach 4 and Notepad++.
Plugged the AC cord to Earthed AC outlet.
I even reinforced Vcc and GND of the VistaCNC MPG handweel.
Its cable has 6 wires but uses only 4. So I soldered non-used 2 wires to VCC and GND each, so that it can have more electric conductivity.
I don't understand why this happens....
Offline thosj
  •  542 542
« Reply #17 on: March 01, 2018, 06:51:54 AM »
I used Daz's Unplugin Plugin to remove the keyboard plugin and it seems better, but I can't really be certain!!
I contacted Lee Neuman of VistaCNC and told him to come here and Warp9 where this has been mentioned, but nothing. I emailed him a week or so ago and he said he's still "working on it."
Someone said they're ordering a P4-S in hopes that will work, but I'm just guessing if the P2-S plugin doesn't work, the P4-S won't either.
Tom
Tom
« Reply #18 on: March 01, 2018, 06:54:05 AM »
Tom
So, now Lee knows that his MPG malfunctions with Mach4?
And he's working on it?
Offline thosj
  •  542 542
« Reply #19 on: March 01, 2018, 07:14:29 AM »
That's what he told me!! Been a while, 'tho!! I'll email him again and point him here again. This ain't doing much for his business!
Tom
