Hello Guest it is November 15, 2026, 09:01:43 PM
Author Topic: Help with small change to homing routine for Z axis  (Read 9276 times)
« on: February 04, 2018, 11:11:39 AM »
I just need to get pointed in the right direction -
I have a Bridgeport Series 2 with air assist on Z axis. If we turn the air off over night and forget to lock the knee the Z will wind up at the bottom of it's travel below the limit and homing switches.
So I want to have the homing routine look at the current position variable, add to it and make a small move to get it above the switches.
Thanks!
Offline Filou
  •  59 59
Re: Help with small change to homing routine for Z axis
« Reply #1 on: February 06, 2018, 11:59:16 PM »
Hi Marc,
before modifying the homing code:
in which status is the z-axis servo motor during the "overnight" period in the event you turned off the air assist ?
enjoy your day, philippe
