Hello Guest it is October 23, 2026, 09:50:35 AM
Author Topic: Real G93 Gcode anyone  (Read 45443 times)
Offline RDR
  •  22 22
Re: Real G93 Gcode anyone
« Reply #30 on: February 05, 2018, 06:59:21 PM »
Hi Mauri
I did some more playing and I have 3 settings for the rotary see attached pic.  I also attached 2 codes I believe that the units/min is what you normally use in mach3 and then let it to the feed rate correction and I also attached the deg/min that may work for you but I'm not sure I think the cam is doing the correction for you instead of the control doing all of the thinking it maybe worth a shot.
« Reply #31 on: February 06, 2018, 09:46:16 AM »
RDR's first gcode looks plausable...  But there seems to be an extra cone and cylinder.
mauri's one looks odd to me - (atleast it doesn't look like the stl...)
Offline RDR
  •  22 22
« Reply #32 on: February 06, 2018, 10:36:27 AM »
Hi skunkworks
I'm not sure on Mauri's file.   I don't think he had my stp file yet if you look back he posted that before I sent over the file so that maybe something he drawn up
Offline Mauri
  •  328 328
« Reply #33 on: February 06, 2018, 01:27:04 PM »
G-Code file that I used was sent before RDR sent his.
Here is the shape from Rhino as the file in any 3D format is too big for this forum.
I have also provided the G-Code with madCAM.
So as you can see Mach4 cannot display this and even a simple circle in G-Code on the ToolPath display in its true form.
Mauri.
« Reply #34 on: February 06, 2018, 01:47:05 PM »
that looks better
Offline RDR
  •  22 22
« Reply #35 on: February 07, 2018, 06:47:28 PM »
https://www.mmsonline.com/columns/programming-feed-rate-in-degrees-per-minute
I Found this site but I am not sure if mach4 hobby can do custom macro B
If so maybe someone can help you with it
« Reply #36 on: February 07, 2018, 08:02:34 PM »
Hobby cannot do custom B but Industrial can.
