Hello Guest it is November 13, 2026, 04:34:25 PM
Author Topic: G49 on Mach3 Mill  (Read 85107 times)
Offline Davek0974
  •  2,606 2,606
Re: G49 on Mach3 Mill
« Reply #70 on: February 12, 2018, 02:50:05 PM »
Back again :)
Not related to G49 but to the code used here.
I'm looking to try drag engraving, so i need the spindle off.
Fusion can't post with a zero spindle speed, it faults and aborts.
So, my thought is to set a speed of 1rpm in Fusion - the mill cannot do this.
Then edit the file load script a little to search this time for "S1 M3" and comment that out.
Does that sound workable - there is no way a proper job can be loaded to run at 1rpm so that should be ok, I also cannot think of any other time that "S1 M3" would appear in code???
Offline rcaffin
  •  1,073 1,073
« Reply #71 on: February 12, 2018, 03:11:03 PM »
Sounds good to me. Edit and delete would be fine too.
Bit poor about Fusion though.
Offline Davek0974
  •  2,606 2,606
« Reply #72 on: February 12, 2018, 03:14:54 PM »
Yes, there are a lot asking for fusion to do static spindle posting, may come one day.
Are drag engravers any good?
Never used one :)
Offline rcaffin
  •  1,073 1,073
« Reply #73 on: February 12, 2018, 03:19:06 PM »
I tried using an MYOG drag engraver once, but the tip snapped off. I was probably mis-using it.
Roger
