Hello Guest it is November 13, 2026, 04:34:23 PM
Author Topic: G49 on Mach3 Mill  (Read 85106 times)
Offline TPS
  •  2,627 2,627
Re: G49 on Mach3 Mill
« Reply #30 on: February 05, 2018, 08:39:07 AM »
ok next Version witch has got a "better" file open Dialog box:
Code: [Select]
Sub Main()
Dim Filename As String
Dim Dialog1
    Set Dialog1 = CreateObject("MSComDlg.CommonDialog")
    Dialog1.MaxFileSize = 256
    Dialog1.Filter = "GCode Files (*.tap)|*.tap"
    Dialog1.FilterIndex = 1
    Dialog1.DialogTitle = "select GCode file"
    Dialog1.InitDir = "C:\Mach3\GCode"
    Dialog1.FileName = ""
    save = false
    If save = true Then
        Dialog1.DefaultExt = def
        Dialog1.Flags = &H800 + &H4
        discard = Dialog1.ShowSave()
    Else
        Dialog1.Flags = &H1000 + &H4 + &H800
        discard = Dialog1.ShowOpen()
    End If
FileName = Dialog1.FileName
If Len(FileName) = 0 Then Exit Sub
'find the last "\" in filename
For i = 1 To Len(FileName)
If Mid(FileName,i,1) = "\" Then
last = i
End If
Next i
'extract filename
myfilename = Mid(FileName,last+1,Len(FileName)-last)
'find the extension in filename
For i = 1 To Len(myfilename)
If Mid(myfilename,i,1) = "." Then
last = i
End If
Next i
'seperate filename and extension
blancfilename = Mid(myfilename,1,last-1)
extension = Mid(myfilename,last,Len(FileName)-last)
'open input file
FNumInput   = FreeFile 'Determine next file number.
Open FileName For Input As FNumInput
'open output file
FNumOutput = FreeFile 'Determine next file number.
Open "C:\Mach3\GCode\" + blancfilename + "_filtered" + extension For Output As FNumOutput
'go through To whole file
Do While Not EOF(FNumInput)
Line Input #FNumInput, FileData ' Read a line of data.
If ((InStr(FileData,"G43") <> 0) And (Left(FileData,1) <> "(")) Then
Print #FNumOutput, "( " + FileData + " )"
Else
Print #FNumOutput, FileData
End If
Loop
Close ' Close all open files.
LoadFile( "C:\Mach3\GCode\" + blancfilename + "_filtered" + extension)
End Sub
if this code is causing error's please run this code once in VB scripter window to Register MSComDlg.CommonDialog :
Code: [Select]
   Set objRegistry = GetObject("winmgmts:\\.\root\default:StdRegProv")
    objRegistry.CreateKey &H80000001, "Software\CLASSES\Licenses\4D553650-6ABE-11cf-8ADB-00AA00C00905"
    objRegistry.SetStringValue &H80000001, "Software\CLASSES\Licenses\4D553650-6ABE-11cf-8ADB-00AA00C00905
Thomas,
who never thought a simple open file Dialog will drive him crazy.
« Last Edit: February 05, 2018, 08:41:23 AM by TPS »
Offline Davek0974
  •  2,606 2,606
« Reply #31 on: February 05, 2018, 08:51:10 AM »
Now, that is outstanding :)
Nicely done.
Ok, so next mini-bug fix is to make the import/load skip straight to the LoadFile part IF the file selected already has "_filtered" in the name - what happens is, next time it is loaded, you get "_filtered_filtered"  and so on :)
Looking damn good though, many thanks.
Offline TPS
  •  2,627 2,627
« Reply #32 on: February 05, 2018, 09:15:04 AM »
here we go:
file is stored in c:\mach3\gcode with original filename
Code: [Select]
Sub Main()
Dim Dialog1
    save = false
    If save = true Then
    Else
    End If
last = i
End If
Next i
'extract filename
last = i
End If
Next i
'open input file
'open output file
Open "C:\Mach3\GCode\import.txt" For Output As FNumOutput
Else
End If
Loop
DoOEMButton(169) 'close Mach3 files just in case
SourceFile = "C:\Mach3\GCode\import.txt"
destfile  = "C:\Mach3\GCode\" + myfilename
FileCopy SourceFile, destfile ' Copy source to target.
Kill SourceFile
LoadFile( "C:\Mach3\GCode\" + myfilename)
End Sub
Offline Davek0974
  •  2,606 2,606
« Reply #33 on: February 05, 2018, 09:53:32 AM »
Very nicely done :)
Much appreciated BTW
Can you go a step further ? :)
Add in a "save as" dialogue box so we can choose to put file anywhere - some of my jobs consist of multiple files within a job folder, cant have them piled into Code folder alone :)
Offline TPS
  •  2,627 2,627
« Reply #34 on: February 05, 2018, 10:39:23 AM »
ok, everything selectable by dialogbox
Code: [Select]
Sub Main()
'get the source file
Dim Dialog1
    save = false
    If save = true Then
    Else
    End If
'get the destination folder
Dim destfolder As String
Dim destfile As String
    Dialog1.DialogTitle = "select destination folder and filename"
    save = true
    If save = true Then
    Else
    End If
destfolder = CurDir
destfile = Dialog1.FileName
If Len(destfolder) = 0 Then Exit Sub
If Len(destfile) = 0 Then Exit Sub
'open input file
'open output file
Else
End If
Loop
Kill SourceFile
LoadFile( destfile)
End Sub
Offline Davek0974
  •  2,606 2,606
« Reply #35 on: February 05, 2018, 11:41:59 AM »
WOW, now that is getting slick ;)
Nicely done there.
Without taking the P which is totally not my intention, can i suggest a luxury add-on, only if it is possible of course?...
Is there a way that when you set the file dialogues, it sets a variable that would remember the path to each dialogue chosen so on the next file it opens in that directory?
Purely a luxury and i know how dodgy variables are in Mach but... ;)
One other tiny little thing - when in the file dialogues if you press "cancel", make it abort the whole loop. ;)
Offline TPS
  •  2,627 2,627
« Reply #36 on: February 05, 2018, 12:19:16 PM »
have you used any UserLabel's ?
if yes, witch ?
probably i can use two free ones to store the last pathe's in.
Offline TPS
  •  2,627 2,627
« Reply #37 on: February 05, 2018, 12:30:06 PM »
ok here is the Version with pathes remembered and Abort on the wright place
used Userlabel 200 and 201 just Change if allready in use
Code: [Select]
Sub Main()
Dim Dialog1
    'get the last selection
    Dialog1.FileName = GetUserLabel(200)
    save = false
    If save = true Then
    Else
    End If
'store last selection
SetUserLabel(200,FileName)
    Dialog1.FileName = GetUserLabel(201)
    save = true
    If save = true Then
    Else
    End If
SetUserLabel(201,destfile)
'open input file
'open output file
Else
End If
Loop
Kill SourceFile
LoadFile( destfile)
End Sub
Offline Davek0974
  •  2,606 2,606
« Reply #38 on: February 05, 2018, 12:52:14 PM »
Persistent file dialogues look good, however the cancel buttons appear to have the same effect as the ok buttons ;)
Getting there though :)
Offline TPS
  •  2,627 2,627
« Reply #39 on: February 05, 2018, 01:26:14 PM »
--> cancel buttons appear to have the same effect as the ok buttons Wink
that is a "side" effect from --> Persistent file dialogues
because the Dialog1.FileName has now allready a value in.
i will have a look tomorrow, how to get the value out witch button was pressed.
Thomas
