Hello Guest it is October 23, 2026, 11:23:27 PM
Author Topic: Lua Fails Me  (Read 18315 times)
Lua Fails Me
« on: January 13, 2018, 02:30:45 PM »
Just when I think i am starting to understand lua I run into this.  The code below is a macro that I have used many times and today I wanted to alter it a bit.  When the changes didn't do what I thought it should i started putting in wxMessagBox calls in to see where it was failing.  When the first message box didn't pop up I was surprised, but even more surprised that the macro continued to execute including the second popup telling me to switch gearing.  What am I missing?  I deleted the .mcc and .mcs.bak several times and completely restarted windows with the same results.  I am at a total loss on this one.
Code: [Select]
function m6691(hVars)
  local xNow,zNow,maxVal,rc
  local ts,tr,te,sCode
  local currPos
  local plungeFeed=1
  local roughDOC=0.018
  local roughFeed=18
  local roughSpeed=1200
  local finishDOC=0.004
  local finishFeed=8
  local finishSpeed=1800
  local endX=.850 --param1()
  local inst=mc.mcGetInstance()
  wx.wxMessageBox('nil')  --HOW  IS THIS SKIPPED?
  if mc.mcSpindleGetCurrentRange(inst)~=1 then
    --rt.rtAudio("notify")
    --wx.wxSound('C:\\mach4Hobby\\Sounds\\Notify.wav',0):Play()
    wx.wxMessageBox('Set Spindle Gearing to High Speed')    --THIS ONE DOES GET EXECUTED!!!
    mc.mcSpindleSetRange(inst,1)
  end
  if (hVars ~= nil) then
    local DFlag = mc.mcCntlGetLocalVarFlag(inst, hVars, mc.SV_D)
    if(DFlag == 1) then
      endX = mc.mcCntlGetLocalVar(inst, hVars, mc.SV_D)
      mc.mcCntlSetLastError(inst,"Turning Diameter to "..endX)
    end
  end
  xNow,rc = mc.mcAxisGetPos(inst,0)
  zNow,rc = mc.mcAxisGetPos(inst,2)
  if xNow<=endX then
    rt.rtAudio("chord")
    wx.wxMessageBox("start X diameter "..xNow.." is <= to end diameter of "..tostring(endX))
    return
  end
  if zNow<=0 then
    rt.rtAudio("chord")
    wx.wxMessageBox("start Z is less than or = to 0")
    return
  end
  ts=os.time()
--rough cuts
  mc.mcCntlGcodeExecuteWait(inst,"M3 S"..tostring(roughSpeed).."\ng04 p3.0")
  currPos,rc=mc.mcAxisGetPos(inst,0)
  while ((currPos-2*roughDOC)>(endX+finishDOC*2)) do
    maxVal=math.max(endX+2*finishDOC,currPos-roughDOC)
    sCode="G01 F"..tostring(plungeFeed).." X"..tostring(maxVal-roughDOC)
    mc.mcCntlGcodeExecuteWait(inst,sCode)
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(roughFeed).." Z0")
    if mc.mcSpindleGetSensorRPM(inst)==0 then
      rt.rtAudio("chord")
      wx.wxMessageBox("Spindle Stopped")
      return
    end
    if currPos==endX+2*finishDOC then
      break
    end
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(plungeFeed).." X"..tostring(math.max(endX+2*finishDOC,currPos-roughDOC)))
      rt.rtAudio("chord")
      return
    end
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(roughFeed).." Z"..tostring(zNow))
    if (currPos)==endX+2*finishDOC then
      break
    end
  end
  tr=os.difftime(os.time(),ts)/60
  mc.mcCntlSetLastError(inst,"Roughing Time: "..string.format("%.1f min",tr))
  --finish cuts
  mc.mcCntlGcodeExecuteWait(inst,"M3 S"..tostring(finishSpeed))
  while (mc.mcAxisGetPos(inst,0)>=(endX+finishDOC)) do
    maxVal=math.max(endX,currPos-finishDOC)
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(plungeFeed).." X"..tostring(maxVal))
      rt.rtAudio("chord")
      return
    end
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(finishFeed).." Z0")
    if currPos==endX then
      break
    end
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(plungeFeed).." X"..tostring(endX))
      rt.rtAudio("chord")
      return
    end
    mc.mcCntlGcodeExecuteWait(inst,"G01 F"..tostring(finishFeed).." Z"..tostring(zNow))
      break
    end
  end
  mc.mcCntlGcodeExecuteWait(inst,"M5\nM9")
  te=(os.time()-ts)/60
  mc.mcCntlSetLastError(inst,"Roughing Time: "..string.format("%.1f min",tr).." - Total Time: "..string.format("%.1f min",te))
end
if mc.mcInEditor()==1 then
  m6691()
end
TIA
RT
Re: Lua Fails Me
« Reply #1 on: January 14, 2018, 01:42:04 PM »
Update:
Decided to give up figuring this out for now so I just deleted the wxMessagebox.
THEN, I changed the finishSpeed and finishFeed to be the same as the roughing feed and speed. Saved it and ran it from the MDI: m6691.  It ran with the old speed and feed for the finish cycle.  Deleted the m6691.mcc and ran it again.  Same result.  Shut windows down and unplugged the pmdx411, restarted windows and plugged the pmdx back in.  Deleted the mcc again and went into the editor checked to make sure that the finish numbers were the same as the roughing and they were, hit compile and the mcc was created again.  Ran it but it still ran the finish cycle with the old numbers!!!
I have searched the computer for any old copies of the mcc file and deleted those in a backup directory along with the mcs and removed them from dropbox as well.  How is it that it is running a file that no longer exists?
TIA
RT
Re: Lua Fails Me
« Reply #2 on: January 14, 2018, 02:12:57 PM »
Further update:
copied and saved the m6691.mcs as m7791.mcs
ran m7791 from the mdi and nothing happened.
deleted the m6691.mcc and moved the m6691.mcs to another directory.  ran m6691 from the mdi and nothing happened.
copied the m6691.mcs back to the macros directory and ran m6691 from the mdi and it created the new m6691.mcc but still ran with the old finish numbers.
Any ideas?
RT
Re: Lua Fails Me
« Reply #3 on: January 14, 2018, 05:45:11 PM »
Did you also delete the lua.mcc file? Anytime you update marcos I would close Mach, delete all .mcc and .bak files in the macros directory. Relaunch Mach and test.
Re: Lua Fails Me
« Reply #4 on: January 15, 2018, 10:02:47 AM »
I did not find a lua.mcc on my machine but I did find a mcLua.mcc.  I deleted it, after shutting down m4, and the result was the same.  I then deleted all mcc and bak files and restarted m4, the result was the same.
I have searched the computer for any files of m6691* and found only the mcs and new mcc created on reload.  I have changed the feeds and speeds in the m6691 script and can confidently state that the file is not being run.   It's as if m4 has retained a compiled version somewhere else.  I am totally baffled on this one.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Lua Fails Me
« Reply #5 on: January 15, 2018, 10:42:27 AM »
Just had a quick look at code, are you using the load modules.mcs?? as there is a bit of code looking for a table at line 34 "rt.rtAudio("chord")"
DazTheGas
Re: Lua Fails Me
« Reply #6 on: January 15, 2018, 11:28:28 AM »
Hi Daz,
Yes I am using it.  I have another macro, m6000 that calls one of the functions and it works,
function m6000()
rt = require 'rtMyModule'
if rt== nil then
  wx.wxMessageBox('rt==nil')
  return
end
local subj='Lathe'
local msg='test m6000'
rt.sendSMS(subj,msg)
end
  m6000()
end
So it seems that rtMyModule located in the profile's 'modules' directory is successfully compiled and loaded by this macro.
Does this help narrow down the problem?
Re: Lua Fails Me
« Reply #7 on: January 15, 2018, 01:07:00 PM »
Had to go blow some snow for the last hour, going to get to below 0 f here later.
Here now is the sum total of the m6691.mcs.  Deleted all bak and mcc in the macro folder and then started m4.
wx.wxMessageBox('hello')
 local rt = require 'rtMyModule'
  if rt== nil then
  return
  end
  local currPos
  local plungeFeed=1
  local roughFeed=18
  local roughSpeed=800
  local finishDOC=0.018
  local finishFeed=18
  local finishSpeed=800
  end
    if(DFlag == 1) then
    end
  end
  if xNow<=endX then
    rt.rtAudio("chord")
    return
  end
  if zNow<=0 then
    rt.rtAudio("chord")
    return
  end
  ts=os.time()
--rough cuts
      rt.rtAudio("chord")
      return
    end
      break
    end
      rt.rtAudio("chord")
      return
    end
      break
    end
  end
  --finish cuts
      rt.rtAudio("chord")
      return
    end
      break
    end
      rt.rtAudio("chord")
      return
    end
      break
    end
  end
  local subj='Lathe'
  local msg='Roughing Complete'
end
  m6691()
end
Guess what,  it still ran the old macro code that doesn't exist!!!
Re: Lua Fails Me
« Reply #8 on: January 18, 2018, 11:45:56 PM »
I may have an answer for you.  I just figured out a similar problem I had on my computer.  I had named a file "write_test" or something, but inside that file I had an old macro function name (M91050) that I forgot to delete, and it screwed everything up until I happened to find it.  Go through all your lua files and look for an m6691 somewhere.
Fingers crossed.
Re: Lua Fails Me
« Reply #9 on: January 20, 2018, 11:26:23 AM »
dbt3000files,
I thought you were on to something so I checked my macros directory and I had saved a copy of m6691.mcs as test.mcs.  So I changed it to test.sav so it wouldn't get compiled and deleted all mcc and bak files and fired up mach.
Ran m6691 in the mdi and same old s..t!! Drat.
I have a ticket in with MFS and James has been able to duplicate it with my package so hopefully they will find where I screwed up.
