Hello Guest it is November 11, 2026, 07:54:14 PM
Author Topic: Stop any movement of axis if Input is not active  (Read 22882 times)
« on: December 28, 2017, 02:15:17 AM »
Hello,
How to stop any movement of axis (when JOGĂ­ng or when G-Code is active) if Input is not active. ?
Cheers!
Re: Stop any movement of axis if Input is not active
« Reply #1 on: December 28, 2017, 06:29:02 AM »
Assign the input as a limit switch?
« Reply #2 on: December 28, 2017, 01:11:09 PM »
Hello,
Thanks for you reply.
But I think no, because I'm using Mach3 for this machine, you can watch on YouTube:
https://www.youtube.com/watch?v=UZgq2EKJ3qE
I need to stop the movement if Nail Gun is in the below, and when he back on the top the movement can be done.
So I think I should write macro to wait (sleep) until Input * is active...
But I'm wondering why there is no such thing to stop axis while G-Code is running to stop movement if button is pressed and when is realease G-Code can be resumed.....
Also I have tried to write a Brain (Input 1 -> No operation -> OEM @250 Inhibit axis movement X) but it's not working while G-Code is running.
Thanks for your answer, if you have any suggestion I will kindly accept it.
Best wishes,
Thanks!
« Last Edit: December 28, 2017, 01:19:07 PM by zmnck »
« Reply #3 on: December 28, 2017, 02:48:53 PM »
Have the button trigger the Feedhold.
Offline TPS
  •  2,627 2,627
« Reply #4 on: December 29, 2017, 01:43:46 AM »
i think you have to "split" this into two parts.
part 1 witch is in the macro what enables the nailer.
here you have to wait for the Input after the nailing something like this:
Code: [Select]
'wait for Input1
While Input1 = false
Sleep(200)
Wend
part 2 will be in macropump, and only stop X-Axis if x-Axis is running and Input1 is off
Code: [Select]
IF ((GetoemDRO(806) > 0) and (Input1 = False)) Then
  DoOEMButton(1003)
End If
Thomas
« Reply #5 on: December 29, 2017, 05:43:39 AM »
Hello,
Very good idea Thomas, thanks.
Can you please explain me what are you calling "macropump" ?
  DoOEMButton(1003)
End If
Thanks.
Offline TPS
  •  2,627 2,627
« Reply #6 on: December 29, 2017, 05:50:12 AM »
OK, no problem.
in your macrofolder (normaly  C:\Mach3\macros\yourprofilename)
should be a macro called macropump.m1s .
if not create one with Texteditor and put These code in:
Code: [Select]
Sub Main()
    DoOEMButton(1003)
  End If
End Sub
make sure that in Config -> General Config -> Run Macro Pump is enabled.
Restart Mach3
test.
Thomas
