Hello Guest it is October 24, 2026, 06:30:49 PM
Author Topic: controlling JP-3163B in 6040T USB CNC with Mach4  (Read 44098 times)
Re: controlling JP-3163B in 6040T USB CNC with Mach4
« Reply #30 on: August 08, 2021, 10:12:53 PM »
the probe is an input into Mach4.
The UC100 in a sense mimics a parallel port and replicates a parallel port numbering.
pin 1   output
pins 2-9 outputs
pins10-13,15 inputs
pins 14,16,17 outputs.
You need to decide which of the very few inputs you have to spare, pins 10-13 and 15, and connect one of them to your probe.
Then in the UC100 plugin you need to connect that pin to Machs Probe signal.
