Hello Guest it is October 20, 2026, 03:09:25 PM
Author Topic: Spindle Control  (Read 23140 times)
Re: Spindle Control
« Reply #10 on: July 08, 2007, 08:06:52 PM »
OK, do you have any docs on this? if so, can you post them?
Re: Spindle Control
« Reply #11 on: July 09, 2007, 08:17:01 AM »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Spindle Control
« Reply #12 on: July 09, 2007, 10:50:19 AM »
Hi, Csaba911
Looking at your info, Your interface board will only turn on & off your spindle by adding a solid state or larger relay to your Aux 1 output.
Your Proxon mill has a var resistor, I think controlling a power transistor for speed control, Don't think you'll be able to change direction though.
There are several boards that will control the speed by simulating the var resistor and use Mach's PWM output.
Can't think of the Mfg. at the moment, Some one will probally jump in about it.
Hope this Helps, Chip
Re: Spindle Control
« Reply #13 on: July 09, 2007, 07:06:47 PM »
Hey Csaba,
    Look in the links section, electronics. I think CNC4PC, maybe Bob Camble, or PMDX will have something to help.
