Hello Guest it is October 24, 2026, 02:33:46 PM
Author Topic: Absolute coordinates in G2/G3 circular interpolation  (Read 61879 times)
gael
« on: July 03, 2007, 11:24:27 AM »
Dear all,
My problem is the following:
It appears that when passing a circular interpolation in the format "G2 X Y I J", the interpolation center (I J) is always interpreted by mach3 as a relative coordinate and never as a an absolute coordinate. Even with the proper G90, X and Y are correctly interpreted as absolute coordinates while I and J are treated as relative coordinates.
What can be done to make Mach3 G-Code interpretation to fit with the norme?
Best regards,
Gaël
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Absolute coordinates in G2/G3 circular interpolation
« Reply #1 on: July 03, 2007, 02:43:23 PM »
At the start of your gcode, on a line of its own enter G90.1 this will tell mach that arc I & J are to be absolute.
Graham.
gael
« Reply #2 on: July 03, 2007, 03:50:25 PM »
Graham,
That's great!!! It works!
Tell me : Have I missed something in Mach3's documentation? Is this "trick" written somewhere?
Best regards,
Gaël
  •  2,785 2,785
« Reply #3 on: July 03, 2007, 05:13:58 PM »
Its in the documents somewhere but I forget where.
Graham.
« Reply #4 on: July 04, 2007, 09:23:30 AM »
You can also change the default IJ mode in the general config screen.
gael
« Reply #5 on: July 04, 2007, 02:19:54 PM »
OK.
I hadn't seen this setting.
