Hello
Guest
it is
October 20, 2026, 02:50:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Digitizing Point Cloud Or "Bed of Nails" type
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Digitizing Point Cloud Or "Bed of Nails" type (Read 25651 times)
ger21
6,295
Re: Digitizing Point Cloud Or "Bed of Nails" type
Reply #10 on:
December 07, 2017, 09:29:00 PM »
Are you talking about the plugin, or the wizard?
Didn't the code I posted fix the wizard?
From memory, I seem to recall that the plugin was broken, and was never fixed.?
Logged
npalen
26
Reply #11 on:
December 07, 2017, 09:58:12 PM »
I'm talking about the digitizing wizard.
Logged
npalen
26
Reply #12 on:
December 07, 2017, 09:59:57 PM »
The code you posted fixed the wizard and I was able to run one sequence to prove it. Then, on a second try, it would not post over to Mach3.
Logged
npalen
26
Reply #13 on:
December 08, 2017, 04:01:13 PM »
Would sure like to get it working.
Logged
ger21
6,295
Reply #14 on:
December 08, 2017, 06:01:17 PM »
I don't know why it doesn't work more than once.
Logged
npalen
26
Reply #15 on:
December 08, 2017, 06:45:23 PM »
Yes, it seems strange that it won't post over to Mach3 after one run. Must be something in the code that needs a reset?
Logged
npalen
26
Reply #16 on:
December 10, 2017, 11:25:14 AM »
This is what I get when trying to debug the modified file:
Logged
ger21
6,295
Reply #17 on:
December 10, 2017, 11:30:39 AM »
you're missing a " after
code " G0 Z0.25
It should be
code "G0 Z0.25"
Logged
npalen
26
Reply #18 on:
December 10, 2017, 07:48:25 PM »
I did get that corrected but am unable to get the digitizer to post any code to mach3. Can you try it there on your end to see if it will work for you?
Thanks for your help.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
