Mach Discussion => General Mach Discussion => Topic started by: npalen on December 01, 2017, 12:05:56 PM
Mach3 has the digitizing plugin which will probe a grid and create a point cloud file as many of you probably know.
I'm wondering if there is a similar digitizing routine "out there" that does the same except after tripping the probe it will simply raise a few thou and then move to the next point on the grid and repeat the process.
This is opposed to returning to Z0 after each hit which wastes a lot of time especially if the item being probed has a lot of depth.
Would anyone know where I might find such a digitizing plugin?
I think that ShotBot has it but it's proprietary.
How would mach 3 know that the next horizontal move won’t be a crash into a higher surface?
The next higher surface would trip the probe immediately when contacting. The the X axis would raise a preset amount and then attempt to move laterally again. This would repeat until X moved a preset amount without tripping the probe and then the scenario repeats.
https://www.youtube.com/watch?v=XjFp0wgvox0
An example
https://www.youtube.com/watch?v=kAHTxzzz91A
Mach3 probing routine with its wasted motion.
In Mach3, load the Digitizing Wizard.
Try this.
Go to Operator > Edit Button Script, and click the "Create and Load G-code" Button. TheMach3 script editor should open, with the Wizard code.
Find these two lines:
code " G31 Z" & Min
code " G0 Z" & Safe
and replace them with
code " G31 Z" & Min
code " G91"
code " G0 Z0.005"
code " G90"
In the Script Editor, go to File > Save, and close the editor.
The modified wizard should now lift the probe .005" after each probe move. Adjust the value as needed (Z0.005)
Test carefully, as I haven't checked to see if this works.
Many thanks, Gerry! Will work on this and see what we come up with. I'm very excited as have been looking for this for several years now.
It probably should be like this:
code " G31 Z" & Min
While IsMoving()
Wend
code " G91"
code " G0 Z0.005"
While IsMoving()
Wend
code " G90"
That seemed to work!!!!
Now after running it once I'm unable to get a new probing routine program to load over into Mach3.
Any thoughts on how I can fix that?
I downloaded a new copy of Mach3 to get the digitizing plug-in to work again.
Would still like to modify the script to allow the retract for only a short distance before the probe moves to the next "hit". This would make a great difference in the time it takes to digitize a large object such as an archtop guitar plate.
Are you talking about the plugin, or the wizard?
Didn't the code I posted fix the wizard?
From memory, I seem to recall that the plugin was broken, and was never fixed.?
I'm talking about the digitizing wizard.
The code you posted fixed the wizard and I was able to run one sequence to prove it. Then, on a second try, it would not post over to Mach3.
Would sure like to get it working.
I don't know why it doesn't work more than once.
Yes, it seems strange that it won't post over to Mach3 after one run. Must be something in the code that needs a reset?
This is what I get when trying to debug the modified file:
you're missing a " after
code " G0 Z0.25
It should be
code "G0 Z0.25"
I did get that corrected but am unable to get the digitizer to post any code to mach3. Can you try it there on your end to see if it will work for you?
Thanks for your help.
